HELP!! Fuel Sending Unit for 1989 Dakota
Old Mar 16, 2020 | 09:16 PM
Tomwsiii's Avatar
Tomwsiii
Default HELP!! Fuel Sending Unit for 1989 Dakota
Does anyone know where I can find one? They are nowhere online that i can find!! Are there any other model sending units that are compatible??? All help is appreciated!
Old Mar 16, 2020 | 11:01 PM
RalphP's Avatar
RalphP
1987 to 1990 or so is about it.
Can you repair your current one?
RwP
Old Mar 17, 2020 | 02:34 PM
onemore94dak's Avatar
onemore94dak
Can you post a picture of the item?
I found this by using your title to search sans help. http://www.onecallfueltanks.com/dakotasender.html
Seems pricey.
and this https://www.carparts.com/fuel-sending-unit/dodge/dakota
https://www.carid.com/dorman/fuel-tank-sending-unit-mpn-2630309.html?singleid=34113826&url=2904429
Old Mar 17, 2020 | 02:59 PM
RalphP's Avatar
RalphP
Originally Posted by onemore94dak
Alas, you're looking at 1991 units; there was a weather change in 1991 - but the 87 to 90 sending units are different, the pumps are different, the tanks are different.
91-93 are the same pumps for 5.2/3.9.
The parts (save for the pump itself!) do not swap with Tomwsii's 1989.
I had to rebuild mine back when I replaced the pump itself (and now it's acting up again, hence my thinking on swapping to a 91-93 tank and pump, since the 1991 was still TBI.)
RwP
Old Mar 17, 2020 | 08:40 PM
onemore94dak
RwP
Sorry I thought I was helping.
Old Mar 22, 2020 | 05:52 PM
Tomwsiii's Avatar
Tomwsiii
Thanks for the feedback guys! I was able to locate a 1988 in a nearby junkyard. I got the whole assembly out of the fuel tank! It sucks they are so hard to find! Hopefully this one will last awhile, if not I may have to get a newer fuel tank as well
Old Jun 4, 2022 | 10:49 AM
Diddybop63's Avatar
Diddybop63
I'm curious as to how you were able to remove the float assembly. I'm looking for a complete tank, because someone decided it was easier to drill holes in my tank to steal my gas.
Old Jun 4, 2022 | 11:35 AM
Given the price of gas.... I suspect that is going to become a lot more common.....
Old Jun 5, 2022 | 11:45 AM
Flounderguy's Avatar
Flounderguy
My truck was stolen a few years ago. I got it back but the thieves did the same thing to me, drilled a hole in the tank to drain the gas. Not an ideal solution, bit a friend was able to patch the hole. This was 6-7 years ago and the patch is still holding.
Old Jun 5, 2022 | 03:27 PM
onemore94dak
If you mean the float arm, it will drop down along the length of the body of the pump as you lift it out of the tank.
