So what are you doing?
Old Dec 12, 2020 | 07:51 PM
  #131
RalphP's Avatar
RalphP
Resurrection ...
Got the bed off today so I can tackle the fuel pump this next Friday (tomorrow is forecast to be raining, and I'm working until Friday.)
RwP
Old Dec 16, 2020 | 05:35 PM
  #132
RalphP's Avatar
RalphP
That was strange.
The tab that the fuel sending unit uses to contact the resistive element on the spare pump I bought? Was ... missing.
Was able to bend the aluminum up to where it fakes it good enough.
But strange, none the less.
RwP
Old Dec 27, 2020 | 04:43 PM
  #133
RalphP's Avatar
RalphP
Finally got the bed off with the help of my stepson.
Finally got the tank cleaned off.
Finally got out there to swap the pumps.
And discovered that my fuel tank was ... empty.
Reservoir was dry, as was where it sits. There WAS a small amount of gas at the front of the tank. But none where the fuel pump was.
I cannot emphasize how dumb I feel at this moment.
Well, the rebuild fuel pump assembly SHOULD have a working fuel gauge sending unit ...
RwP
Old Dec 27, 2020 | 05:23 PM
  #134
ol' grouch's Avatar
ol' grouch
RwP
I'd point and laugh if I hadn't done the same thing. I was going to sell a truck cheap once and the guy wanted it even cheaper. I didn't sell it, put some fuel in and it fired right up.
Old Dec 27, 2020 | 09:47 PM
  #135
I think we have all been there at some point or other.
Old Dec 28, 2020 | 10:51 AM
  #136
Glen440's Avatar
Glen440
I fixed the fuel gauge on my 87 when I bought it. A wire had corroded between the sender and the firewall connector. All the wires in the back are black and will need replaced. I cleaned the contact on the sending unit and put it back in. You can check them with an ohm meter.
I first checked the cluster gauge with a chevy sending unit I had, it is wrong for the ohms but triggers a response. Think it would only go to half tank.
Old Jan 3, 2021 | 05:10 PM
  #137
RalphP's Avatar
RalphP
Rebuilt fuel pump assembly (with new Bosch fuel pump) is now in truck.
4 gallons of gas added.
Truck starts, idles nicely.
Set timing to about 15* BTDC; I'm going to squeeze every erg I can out of the gasoline I'll be running.
Still need to finish pressure washing the underside and upperside of the bed, then put the bed back on, then the topper.
But it's progressing.
RwP
Old Jan 4, 2021 | 07:04 PM
  #138
ol' grouch's Avatar
ol' grouch
I'm making progress on the "Granny" car I picked up.I'm rebuilding the front end and will be pulling the upper timing cover to check the timing belt.
Old Jan 9, 2021 | 06:41 PM
  #139
RalphP's Avatar
RalphP
I see you got a ZZTopMobile there.
I always thought they were cute.
Hopefully it does well for you.
RwP
Old Jan 9, 2021 | 06:43 PM
  #140
RalphP's Avatar
RalphP
Stepson helped me put the bed on Thursday (placing it).
I got all nine bolts (eight into frame or frame horns; one for the ground wires) tightened down and blue Loktite'ed . I also made sure the wiring was plugged back in for both tail lights.
Time to figure out what size hole to drill for the slide switch and do the bed lights, methinks, before the camper top goes back on.
RwP
