i am fixing my 1990 Dakota with a 2.5 liter and the vacuum lines are messed up. i am trying to figure out where the two solenoids are one is for the EGR and the other is for the purge solenoid. i am also missing the PCV check valve and the orifice that goes into the vacuum fittings. nobody sells them new and i haven't found any used.
RalphP
close
- Join DateJan 2013
- LocationNorthwest Louisiana
Liked:374 Times in 345 Posts
The PCV check valve? Shucks, they're all over the place - but I'd stick with Mopar. Unless there's something besides the PCV valve itself you're talking about.
The orifice - yah, best deal there I've found was to fill a joint, then drill a 1/8" hole through it.
Do you have pictures?
RwP
RwP
no pics yet. i got most of my vacuum figured out . just took the hard plastic lines off as they were breaking any way got the rest figured out except the two solinoids one egr and one purge which is which no i don't have a book.
RalphP
close
- Join DateJan 2013
And you don't have the VECI from under the hood?
You might try the plumbing of the 1995 2.5; it should be close. No guarantee.
The 1995 FSM is downloadable from the link in the FAQ here; for a 1990, you'll probably have to blow the $40 or so for one on disc.
RwP
RwP
i have the sticker under the hood but all it says is egr solinoid and purge solinoid. i finally found it online and had to sort through a lot of pages until i found it. that's when i desised to throw out the hard plastic lines and go with the rubber hose.
it shows the routing and the components but there are two solenoids that look identical i had to figure out which was which.
RalphP
close
- Join DateJan 2013
Ah.
You never stated that, so nobody else knew.
But - that's one reason to order the FSM. It'll have what color wire does what.
Also, worst case, you get it backwards, you swap the vacuum lines or the connectors; the solenoids themselves are identical.
Presuming the color code didn't get screwed up from 1990 to 1995, the 1995 FSM page 8W-30-17 would have which is which.
OTOH, if the colors don't match, well ... at least it's a no charge download to look
RwP
RwP
