T-Case swap
Old Nov 25, 2020 | 08:06 PM
ZarekG's Avatar
ZarekG
Default T-Case swap
Hey y’all, I need to change the transfer case on my 97 Dodge Dakota 3.9l, 5spd manual
I just got the old one pulled,
It’s a 231j, I’m having trouble finding a replacement, I’ve seen online that with jeeps you could interchange the 231 and the 242, is that true with the Dakota?
Here’s the one I just pulled.. pretty messed up
Old Nov 25, 2020 | 08:41 PM
00t444e's Avatar
00t444e
If its an NP231J then it came out of a Jeep. An NP231D is out of a Dodge.
Old Nov 26, 2020 | 08:52 PM
ZarekG's Avatar
ZarekG
Oh okay, interesting. Do you know if the 342 would work?
Old Nov 26, 2020 | 09:05 PM
00t444e's Avatar
00t444e
A np242 will bolt up if it has the correct input shaft, but then you will have 5 shifter positions instead of 4 which may not be a problem. If it was me I would try to find an NP231, I had a couple NP242s in Jeeps and I wasn't a fan of them, I swapped the NP242 out for an NP231 on the Jeep I have now.
Old Nov 26, 2020 | 11:11 PM
ZarekG's Avatar
ZarekG
Okay that’s good to know, at the moment I’m just trying to get the truck running so I have a vehicle so it might just be worth it. I’m finding the 242 are a lot easier to come by than the 231s. However if I can find a 231 I’ll use it. Any recommendations on where I could find one under 300$?
Old Nov 26, 2020 | 11:23 PM
RalphP's Avatar
RalphP
Hit up car-part.com and see if any turn up?
RwP
Old Dec 13, 2020 | 12:06 AM
crazyjerry's Avatar
crazyjerry
metal tag on the back says what model it is. 231D. probly completetly caked with crusty oil i suppose. should be a ton of them in every salvage yard
Old Jan 11, 2021 | 05:59 PM
ZarekG's Avatar
ZarekG
I did its an np231j.. Have had to replace this once already. Can't seem to find any at the salvage yards around me..
