Fuel tank repar - 1988 dakota
Two things. What year tanks are compatible with 88?
I used a two part gas tank repair epoxy (It might be JB) on a metal tank that was wet with the gas dripping out of it. It is still working more than 14 years later.
Are you sure about this?
About a year or two ago, I purchased a tank from an individual. He pulled the pump assembly out and washed the insides with soap and water. Boxed it up and mailed it.
I was a little concerned at first, but in reality, the tank is plastic with no baffles. Has a large hole where the pump goes, so reaching in is not a problem.
Very easy to remove all gas.........
The problem with shipping a fuel tank isn't so much left over gasoline but the fumes that out gas for months after emptying. I've seen empty tanks ignite when cutting torch sparks got in. A full tank is actually safer to handle. Still, $1000 does seem pretty high. I think they just didn't want to fool with it. DOT and other regulations are pretty problematic.
Swapping to a new fuel pump assembly? Add 1991-1996. Same part number tanks for all six years.
RwP
I'm not sure how much blackbird wants to spend but here is a 91 tank for $305.69 free shipping https://www.ebay.com/itm/Gas-Fuel-Ta...oAAOSwE5pfkVZW
and a fuel pump for a 91-96 for $48 free shipping https://www.ebay.com/itm/New-Fuel-Pu...UAAOSwMIhfWojG
RwP
That was just a quick search. IDK what the OP can spend. I paid $145 for my Airtex from Autozone when I bought the truck then broke the rollover valve.changing it over. I ended up finding a pump straight out of a tank half full of gas at a junkyard, they hadn't drained it yet, which is what I have in there now. I did the aftermarket fix of the rollover valve in the Airtex pump which I have as a spare. I used it for a few months.
Anyway I think there are more tanks of the 91 to 96 variety on ebay. IDK what OP may be able to find for fuel pumps.
Lots of plain ole internet myth here......
IF a plastic tank is washed with soap and water, flushed and dried, there will not be any fumes left that will ignite. Of course, we all know, the liquid gas will not burn, it is the evaporation (fumes) that ignite. But with all gas, there has to be the correct amount of oxygen to mix and support combustion. ie: when the fuel ratio in the engine starts going much above 15 to 1, it will not burn.....
If you do a search, you will see people advertising on ebay selling tanks shipped...
One last point to consider, companies that rebuild carbs, or fuel injectors..... Much more potential for actual gas to be shipped , as compared to a plastic tank that has been washed and dried.... And carbs, and injectors are being shipped every day.
Again, dont buy into all the internet myths.
I don't pay much attention to what people say on the internet. My experience goes back well before there was an internet. I'm thinking more along the lines of D.O.T. regulations. Go to any well run salvage yard. Fuel tanks are pulled, drained then stored away from everything else.
