couple newb questions :)
Old Dec 27, 2005 | 12:37 AM
Ruggels's Avatar
Ruggels
Default couple newb questions :)
First of All i wanan say hi im new to the site .. i just bought a dakota .. 4x4 everything works tonneua cover truck cap 4 steelies with rubber and 4 mags with rubber for 800 bucks is tha tgood :P ?? oy ya and apologize for my ill knowledge of trucks :P
ok here goes the newbie questions
i hav ea 92 dakota 4x4 3.9l reg cab .. currently on 235 75 15 tires ..
i have the stock dakota mags from that year that came with it .. whats about a decent size tire i can put caus ei was thikning 31" is that posisble ?
as i read a few posts down it seems it would be possible t put some 2nd gen Rims on my truck ? i assume they are 6 bolt as well ?
second any easy mods i can do to gain some hp andperformance nothing major as of yet ..
third lol if i get a 318 and stick it in here ? will it bolt up to curent tranny ?
Thanks for the time guys im sur eill be on her eposting alot :P
Thanks
Kirk
Old Dec 27, 2005 | 02:12 AM
360DakotaPwr's Avatar
360DakotaPwr
Default RE: couple newb questions :)
Welcome
31 in tires should fit fine on a 4x4
Late style rims are a problem for the 2wd, but I will let someone else explain it for ya on the 4x4 (not as difficult).
Any motor swap stuff related to 92 up V6 to V8 swap (especially with an AUTO trans) then I will claim to know what I'm talking about. 318 or 360 will bolt up fine. I can give you pretty much any info you would need to do the swap.
Old Dec 27, 2005 | 02:27 AM
360DakotaPwr
Contact JDakota92 about the rims on a 4x4, I think he has them on his.
Old Dec 27, 2005 | 12:44 PM
Ruggels's Avatar
Ruggels
Thanks for the info :P now to find a 360 then lol if that will fit ..
would love to get a big monstor in there and see what she can do :P
thanks again for the reply
Old Dec 28, 2005 | 01:31 AM
360DakotaPwr
OH, it will fit, and a big difference it is from a V6. Even just a stock 360! Let me know if you have any questions about doing the swap, I can tell you any problems that you might run into. Shoot me an e-mail or post anything you wanna know, I'm willing to give you any info I have.
Old Dec 29, 2005 | 12:47 PM
Sneezer's Avatar
Sneezer
I am in the process of putting a 360 in my 92, which currently has 191k mile 318 in it. The engine is just about complete, I just need a couple odds and ends left to finish the swap. Hoping to get it done next month, money permitting.
Old Dec 30, 2005 | 02:52 AM
360DakotaPwr
What year engine and flywheel. Auto or stick?
Old Dec 30, 2005 | 12:23 PM
Sneezer's Avatar
Sneezer
92 318 - owned since new. Using the stock 518 tranny, was rebuilt a couple years ago. Engine going in is a 2000 Durango 360. Swapped back to the pre-2000 balancer so I could use my underdrive pulleys. Came with the flexplate, but I had to get a different TQ since they changed the bolt pattern and balancing around 96/97. I wanted to move up to a 2400 stall anyway. Engine has about 30k miles on it. Gonna have a host of other goodies in it too! Nothing over the top, but it will be a definite kick in the pants over the old mill.
Old Dec 30, 2005 | 01:24 PM
Ruggels's Avatar
Ruggels
goos show man hope that you enjoy the 360 .. after seeing how much gas this beast drinks lol i think the 3.9l lol will be fine for now .. jesus she ever hard on gas im gonn ago an dlook and see if any gas is leaking outside under the truck lol
goo dluck with your swap for sure .. im silly enough that if i find a 318 ill prob swap to lol anywyas talk to you all soon ..
Old Dec 30, 2005 | 08:55 PM
360DakotaPwr
Ok sounds good, the motor is balenced by the flexplate. Thats what I was wondering if you relized the bolt pattern change. I take it you bought a 90 degree bolt pattern torque converter. 96 up. Only other thing to check is the torque converter snout. Early 500 trannys had notches cut in the torque converter snout and late model ones have flat spots milled oposite eachother on the snout. I dunno about 518's. I think they were always notched, but I'm not positive because I'm running a 500 trans and I didnt really pay much attention to the 518.
A 92 318 computer will run the 360 perfect, but you may prefer one from a 94 or 95 dodge ram with a 360. They also work, and for gas mileage it seemed to work a little better. If not then an upgraded ECU also works great. Good Luck.
