Suspension Plus
Old Dec 23, 2021 | 11:25 PM
  #461
RalphP's Avatar
RalphP
Around here, the All You Can Carry days don't let you use a hood or trunk lid anymore; none of it can be touching the ground.
OTOH, another chain's been doing "$19.99 Bucket" where you bring in a 5 gallon bucket and if it fits it sells.
Too bad I can't shove truck doors, hoods, or fenders into that bucket ...
RwP
Old Dec 24, 2021 | 08:50 AM
  #462
bronze's Avatar
bronze
RwP
Mount a luggage rack on the bucket.
Old Dec 24, 2021 | 02:02 PM
  #463
bronze's Avatar
bronze
In the FSM, check page 13-49.
Quoting from the bottom left:
RwP
What FSM are you reading from?
Old Dec 24, 2021 | 05:15 PM
  #464
RalphP's Avatar
RalphP
Can't type.
Page 14-29 - 20 pages earlier.
Well, there isn't a 14-49 in the 1993 FSM that I quoted. Did I misremember your year?
RwP
Old Dec 24, 2021 | 05:37 PM
  #465
bronze's Avatar
bronze
No, you’re memory is working perfectly fine. I, indeed, have a ‘93. It’s likely me who is having prefrontal cortex failure. I am using the page counter on the Adobe PDF app on my laptop. I’m kinda getting the feeling you are referring to a different paging scheme.
Old Dec 24, 2021 | 07:26 PM
  #466
RalphP's Avatar
RalphP
Chapter 14, page 29.
Hrmm ... Foxit Reader will go to page 14-29 cleanly.
Page 648 approx. in Foxit.
RwP
Old Dec 24, 2021 | 10:13 PM
  #467
bronze's Avatar
bronze
Originally Posted by RalphP;[url=tel:3533239
3533239]Chapter 14, page 29.
RwP
OK, I’m with you now. It’s page 648 on Adobe too.
I see the FSM has you disconnecting 90% of the truck and lifting the entire cab off the frame. Geez! Of course that is a “Cab Removal” instruction, not a “Body Mount Replace”. I don’t think they have a section for “Body Mount Replace”.
So if I’m reading that right, the candlestick holder is called a compression isolator spacer??
Old Dec 24, 2021 | 11:38 PM
  #468
RalphP's Avatar
RalphP
Yep, that's what they call it.
That's where the spec the torque setting; it's part of the big job. We just don't have to do ALL of that job
RwP
Old Dec 25, 2021 | 06:14 AM
  #469
bronze's Avatar
bronze
Merry Christmas to all!
Old Dec 25, 2021 | 08:01 AM
  #470
bronze's Avatar
bronze
I looked up the body mount part #s for my '93. They show only the standard cab. Nothing on my extended cab. What's interesting is they show two different candlestick holders. The core support and rear cab mount share the same part# and the front cab mount has its own part# (I would have guessed the two cab holders would be the same and the core holder different). Furthermore, all three have different part#s for the upper isolator. I believe the ES kit has the same part for the two cab mount upper isolators and the core has its own part#. Looks inconsistent. Hmmm. All three lower isolators share the same part# which would be consistent with the ES kit.
Ralph, I don't know if your '88 is the same as my '93 but this may apply. And it looks like the standard cab has some body mount differences vs the extended cab in terms of body mount part configurations but I cannot tell from the parts catalog.
