New member from Greece
Old Nov 14, 2021 | 03:23 PM
RalphP's Avatar
RalphP
First, build a time machine ...
Yah, the last company making them, the dies wore out and they didn't see any reason to make more.
If you go to Raybuck.COM and leave a message on 1987-1996 Dodge Dakota Beltline Seals (Outer) (raybuck.com) you may be notified if they come back.
In the meantime, some of us are measuring and checking sites like Steele Rubber, to see if there's a generic we can glue to a stripped old seal to make something usable.
RwP
Old Nov 14, 2021 | 07:31 PM
bronze's Avatar
bronze
Lemme know if you come up with anything. Mine are shot too.
Old Nov 15, 2021 | 07:29 AM
Can LMC Truck still get 'em?
Old Nov 15, 2021 | 08:19 AM
RalphP's Avatar
RalphP
LMC doesn't have anything specific to the 1st Gens.
So no, they never were able to get them.
RwP
Old Nov 15, 2021 | 09:10 AM
mama_scorpion's Avatar
mama_scorpion
Welcome! I really like your truck.
Old Nov 15, 2021 | 09:55 AM
jimys's Avatar
jimys
thank you I’m proud owner for this beauty
hard work came with pretty good results
Old Nov 16, 2021 | 01:54 AM
crazyjerry's Avatar
crazyjerry
just dload the '95 service manual at the top in faq. it has all information to fix everything
Old Nov 16, 2021 | 06:48 AM
jimys's Avatar
jimys
Thank you for your help
question
has mine Dakota front spring coils because as you can see in pic it hasn’t
it has only absorbers is it normal or something is wrong ?
Old Nov 16, 2021 | 09:29 AM
ol' grouch's Avatar
ol' grouch
question
You don't have coil springs. You have torsion bars. Think of a coil spring straightened out. Then bend it at a 90 degree angle. The bar goes into the frame under your feet. The bend goes out to the lower control arm. Chrysler started using this setup around 1960.
Δεν έχετε σπειροειδή ελατήρια. Έχετε ράβδους στρέψης. Σκεφτείτε ένα πηνίο άνοιξη ισιώσει έξω. Στη συνέχεια, λυγίστε το σε γωνία 90 μοιρών. Το μπαρ πηγαίνει στο πλαίσιο κάτω από τα πόδια σας. Η κάμψη βγαίνει στον κάτω βραχίονα ελέγχου. Η Chrysler άρχισε να χρησιμοποιεί αυτή τη ρύθμιση γύρω στο 1960.
Old Nov 16, 2021 | 10:08 AM
onemore94dak's Avatar
onemore94dak
I assume you can buy online. If so here is the FSM on CD $36.29US I used the 1995 service manual from the FAQ section for my 94 for years before I finally bought one for the 94.
http://www.autobooksbishko.com/Items...ual/15055.html
