94 Dakota abs bleed process help, please
Old 11-13-2021, 05:14 AM
angieford's Avatar
angieford
angieford is offline
Lightbulb 94 Dakota abs bleed process help, please
hI. iVE GOT A 94 4X4 DAKOTA. I would like tom know what the procedure is for bleeding the abs system. The Light has been on since I got it. So I know after reading all the different threads here, to basically disconnect every thing and clean it then re connect every thing. sounds pretty textbook. Nothing like my 67 ford 100/ 1ton high boy shortbed. HaHaahaa had to give her a salute. Anyway. thank you kindly. In advance. I appreciate the sound reply.
Old 11-13-2021, 05:31 AM
angieford's Avatar
angieford
Default 94 dakota abs brake system diagram?
Well, I would be so gracious for a picture of the abs system or schematic, or..... anything to help me with troubleshooting the dang parts cuz Im pretty sure some of its parts are assembled incorrectly. parking brake wont work and it's cinched up tight.
If anyone has any other help here, It's appreciated.
Old 11-13-2021, 09:20 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,230 Likes on 2,980 Posts
Isn't there a 94 or 95 service manual available in one of the sticky threads?
Do you have 4wheel anti lock, or just rear wheel?
Old 11-13-2021, 11:32 AM
bronze's Avatar
bronze
bronze is offline
Indeed, there is a '95 FSM in the sticky section.
Old 11-13-2021, 01:13 PM
RalphP's Avatar
RalphP
RalphP is offline
The 1994 factory service manual should be your go-to and your bible.
HOWEVER.
As pointed out, the 1995 (a sister year, almost identical, but here it's not your bible, but a close transliteration thereof) FSM is in the FAQ stickied message, Well, a link to it, about 40% of the way down.
Also right below (or above, not sure offhand, and can't be arsed to check for you) is the factory parts list. I'd get that, and all the other years for the stuff that's "Assembly 1234 576" in 1994, but "Bushings 5321 123, Bushing 5321 321, Arm ..." etc. for earlier years. (Wiper transmission in particular!)
That 1995 manual will show you how it's SUPPOSED to be plumbed.
DO note if you have 4WAL or RWAL on your truck; the plumbing will be different.
RwP
Quick Reply: 94 Dakota abs bleed process help, please
