Trk won't start no spark
Old Mar 17, 2022 | 08:29 PM
Leroy66's Avatar
Leroy66
Default Trk won't start no spark
I have a 94 dodge dakota 4x2 3.9l it will not start. I've replace coil and pick up and distributor and rotor and crank sensor I have replaced relays and checked fuses and checked the wires under the fuse block where 3 go into 1.got 12v going to pcm but I don't have power to fuel pump or coil or pick up.checked for codes but it will not flash anything
Old Mar 18, 2022 | 08:50 AM
Welcome to DF! Moving this to first gen dakota section for ya.
Old Mar 18, 2022 | 09:22 AM
onemore94dak's Avatar
onemore94dak
OK get an FSM as soon as possible. There is a 95 and 96 fsm you can download in the FAQ sticky thread about half way down. The 95 worked ok for me until I got my 94 but there are differences. Bishko the OE publisher sells paper and CD versions still. $40 for the CD + shipping and it doesn't get grease on it. Just the laptop
OK Your post makes me think ASD relay. IDK a lot but the relay box is above the splice and apparently the ASD and another relay are the same so if one works you can swap it over to the other slot to see if that is the problem. Other guys on here know a lot more than I.
Old Mar 18, 2022 | 09:55 AM
bronze's Avatar
bronze
I wish someone would tell me how to take preventative measures to keep that splice from going bad like it does for so many others (I've asked a few times). Mine has never been a problem but I'd like to keep it that way. And not fully understanding exactly what the "splice" problem is I'd like to do something about it before it claims me as another victim. I just know it's in the harness leading up to the fuse/relay box.
Old Mar 26, 2022 | 08:17 PM
Leroy66's Avatar
Leroy66
Ok I have replaced the ECM and replaced engine wiring harness and replaced all relays it started and ran for about 10 mins then shut off and now back to square 1 I have power on all relays except power on 1 of the 4 relays fuel pump works when applied power asd has power except 1 wire the green/orange wire
Old Mar 27, 2022 | 09:12 AM
onemore94dak
You replaced the engine wiring harness?! Are you sure the replacement harness was good? Otherwise this is above my pay grade.
Old Mar 27, 2022 | 10:44 AM
Leroy66's Avatar
Leroy66
Yes engine harness is good ohm wires before putting it on.
I have power on pin 30 and 87 and 85 but not on pin 86 on fuel pump or ASD when switch is on or turning it over.shouldn't I have power when starting??
Old Mar 28, 2022 | 08:18 AM
Does the fuel pump prime when you first turn the key on?
PCM will only energize the ASD and Fuel pump relays for about three seconds at key on, after that, it needs to see the engine turning, via the crank sensor. If you get the prime, but nothing while cranking, that sensor is the first thing I would check.
