Seat Belt and Tire Questions 93 Dakota V8
Old Apr 28, 2022 | 09:17 AM
onemore94dak's Avatar
onemore94dak
Originally Posted by Stch_Fix
This one has a quite a bit of fraying on the sides so I am not sure if being dirty is only the problem but I might give that a try. Thanks
I have the old ones that don't reel back in around here somewhere. If you look up a recently passed member Ralph P, posts he had some after market shop that sold new ones a lot cheaper than OE belts. He posted a lot so it might be easier to log in and search seat belts on the site.
Old Apr 28, 2022 | 02:45 PM
Stch_Fix's Avatar
Stch_Fix
Thanks! I will keep that in mind. I am working on several things at once on this truck lol. Thank God none of it is the actual engine. It was a $600 truck that couldn't go in reverse when I bought it. Got a reman eBay trans dropped in and it's been a pretty great truck so far but I like trying to make my cars close the original shape as possible. Or customize them.
Old Apr 28, 2022 | 02:49 PM
Stch_Fix's Avatar
Stch_Fix
Originally Posted by bronze
I had seepage coming from the pump (bottom of pump and hoses were damp with fluid). Was only going to get worse. Knew it wasn't the rack because I changed the inner tie rods last Fall and there was no leakage around the seals. Replaced pump AND both hoses AND added a 3/8" Magnefine filter. Did a thorough flush (plenty of videos on You Tube).
I got under there today, there is some "dried" wetness (if that makes any sense) on the bottom of the pump AND there's fluid leaking from some line on the rack on the driver side. Both covers have fluid "drived" on them. I didn't put them back. But I took pics...
