vehicle swerving
vehicle swerving
94 Dakota LST 5.2ltr 4WD Auto trans: When driving at about 35mph the vehicle suddenly swerved to the right. I turned the steering wheel, a bit harder than normal, to get back to going straight. A few blocks later the vehicle swerved to the left. I got home, Jacked up front end and with tires off could find nothing loose. The local (Les Schwab) tire center mechanic checked out everything in front end suspension and steering and found nothing out of order. Could the vehicle swerve both ways because of a malfunction in the power steering pump (the only thing he couldn't check out) or some other reason? Tires inflated properly with no indication of unusual wear. Front brakes are good but rear could be in need of replacing as they have started to squeel. Have had no problems in the last 15 miles of driving without exceeding 35 mph. Any ideas? Thanks, #95
P.S. With the right front jacked up with the tire about an inch off the ground I turned the steering wheel to the left to get the wheels straight. At about a qurter turn on the wheel there was a sharp clank and the tire was now back to touching the ground. The jack was not the problem.
Ooh! Bad mojo there! It should NOT shift while supported. A failure in the P.S. pump would cost you power assist, but not make it swerve. Did he check your track bar? Something is definitely binding.
