Rear brake lines
Old Jan 25, 2023 | 12:23 PM
  #21
onemore94dak's Avatar
onemore94dak
If you go with making your own HF has a cheap set of pliers to make it easier and less likely you will kink it
https://www.harborfreight.com/tube-b...ers-95782.html
I never messed with mine I just replaced the ends that go to rubber tubing. They were hard to unscrew without breaking the metal tubes. Two Wrenches and patience.
Old Jan 25, 2023 | 12:30 PM
  #22
bronze's Avatar
bronze
Obviously he will need to bleed his brakes. Good time to go around the entire truck and do a complete flush. If you recall HY, I couldn't get my brakes to bleed to save my life. Pneumatic, two-man, nothing worked. I was convinced I had a leak somewhere. Then our late friend Ralph suggested a gravity bleed and that did the trick. I believe you encouraged me to follow up with a two-man to get any trapped air. That yielded a tiny bit more air to escape and the brakes have been flawless since. I ended up with pretty much a new brake system. Only thing I did not change out is the booster, ABS, proportional valve, and front-to-back brake line. A couple months ago some lady pulled out in front of me from a side street. I was doing 55 and had to stand on the brakes. Smoked the tires and fortunately for her I was able to jerk it in the oncoming lane and avoid her just barely. Good thing there was no traffic. I woulda killed her if there were cars coming the other way. My only choice would be to T-bone her. But I got to thinking, my ABS did not activate (might explain why I smoked the tires too). I have rear ABS only. I think ABS systems have a shelf life on most vehicles.
Old Jan 25, 2023 | 12:34 PM
  #23
onemore94dak
I had that happen to me a few years ago in Seattle on an overpass the rear wheels locked up. It was raining. ??? Not since and i have stopped hard a few times. Maybe it was the wet?
Old Jan 25, 2023 | 12:38 PM
  #24
bronze's Avatar
bronze
Yeah, ABS has value but I don't think they've ever been built to last. Guessing they're more computer controlled now vs on my '93.
Old Jan 26, 2023 | 09:58 AM
  #25
zacgarlew's Avatar
zacgarlew
Default Job complete
Thank you everyone for your input and guidance! I was able to buy the line and a cheap bending tool and got my line made, bled all my brakes and it's like I've got new brakes again.
A sincere thanks!!!
