1993 Dodge Dakota display light not working.
Old Mar 13, 2023 | 09:07 PM
AustinCberry's Avatar
AustinCberry
Absolutely fella’s next is to figure out my weird Idle problem. Truck when started just revs up past 2000 rpm’s and then drops and goes back up again and Again. Sometimes at a stop light it will rev up and I have to hold the breaks down so it doesn’t take off. I ordered a map sensor and a tps sensor I’m going to start there. I checked vacuum lines I can’t see any bad but I may be wrong. Just waiting on the parts to come in.
Old Mar 13, 2023 | 09:23 PM
AustinCberry
Originally Posted by onemore94dak
Guess how I found out there is such a thing as a firing order? I also found out in that incident that your local Free Public Library usually has some Chilton and Haynes manuals which are better than nothing and do have the firing order in them.
oh my lord that’s a rough way to find out about that. I got my trusty Hanes Manuel if I really need it.
Old Mar 14, 2023 | 12:41 PM
tndakman's Avatar
tndakman
On the comments concerning the Haynes & Chilton manuals our dearly departed guru of all things 1st Gen Dakota RalphP would have said " It's not a Chilton Dakota nor is it a Haynes Dakota get a FSM". And he would have told you where to download one if available on this sub-Forum or recommended one from Bishko, either paper or digital (DVD). AFAIK they are still the licensed publisher of the said FSM. Just sayin'.
Old Mar 14, 2023 | 03:03 PM
onemore94dak's Avatar
onemore94dak
You are correct on all points sir.
It's the 95 and 96 FSM that are in the FAQ section.
