The quest begins: Intermittent Stall.
Old Apr 9, 2023 | 05:25 PM
bctom's Avatar
bctom
Default The quest begins: Intermittent Stall.
What kind of current will be drawn from the battery when the truck is shut off? When I check the parasitic draw on the battery it’s showing 1.35amps. That seems high seeing as there is only the radio drawing current to maintain presets and clock.
1992 2wd LE ext cab, a/c, tilt column, cruise control. Relatively rust free. Only add ons is 7pole trailer plug from previous owner.
I’m in the garage on my nearly dead phone and will post more in another thread soon.
Thanks
tom
Old Apr 9, 2023 | 07:34 PM
That's too much. Should be less than 1 amp. (possibly, quite a bit less....)
Old Apr 9, 2023 | 07:49 PM
bronze's Avatar
bronze
What would cause it to draw 1.35A, HY? I'm curious.
Old Apr 10, 2023 | 07:35 AM
Could be anything. On the old chevy trucks, the underhood lamp, or glovebox lamp were usually the culprit. With todays vehicles though, with more computer power than all of nasa during the height of the shuttle program..... there are so many possibilities, it's almost impossible to count.
Old Apr 10, 2023 | 08:16 AM
bronze's Avatar
bronze
Hmmm. I'd consider disconnecting the radio first to see what impact it has on the amp draw.
Old Apr 11, 2023 | 02:56 AM
bctom's Avatar
bctom
Default update to parasitic draw
Well, I went out to double check that I didnt leave a light or fan on while checking with the multi metre. I didn't as it turns out. But when I checked the draw with the metre again there was no amperage being drawn. So that's something.
When I get the photos off my phone I'll start a new thread on the stalling.
Thanks for your help.
Tom
Old Apr 11, 2023 | 01:30 PM
onemore94dak's Avatar
onemore94dak
So I have another truck with a parasitic draw. I have to leave the battery disconnected so its ready to run when I need it. Anyway your post made me look up the how of it and It turns out checking the thing is not as hard as I was imagining. I haven't done anything about it yet., waiting for rain to stop, but I found this page and the instructions are simple enough even I can do it.
https://www.wikihow.com/Find-a-Parasitic-Battery-Drain
Old Apr 11, 2023 | 01:43 PM
bronze's Avatar
bronze
With my recent record, I'd still find a way to screw it up.
