what is the problem
Old May 17, 2023 | 01:47 PM
tjohn's Avatar
tjohn
Default what is the problem
My 1995 dodge dakota has been acting a little strange lately, wants missfire , even to the point of back firing. Could it be the crank sensor ,or the camshaft sensor, a a fautly fuel pump. This morning I was driving up the driveway ( back fireing all the way ) when it decided to run prefectly, short burst, then starting back fireing again. Any help you can answer !!
Old May 17, 2023 | 04:12 PM
Getting any codes?
Old May 18, 2023 | 10:31 AM
tjohn's Avatar
tjohn
Getting any codes?
Through the on the ignition. Just a 1-2 and then 5-5
Old May 18, 2023 | 11:22 AM
So far as the PCM is concerned, there aren't any problems then. Ain't that fun? Check your fuel pressure, see what it looks like.
Old May 18, 2023 | 11:35 AM
bronze's Avatar
bronze
What should the fuel pressure be (about) for the V6 and the V8?
Old May 18, 2023 | 11:36 AM
I think it should be in the neighborhood of 40PSI at idle. Should stay close to that as you rev the engine.
Old May 18, 2023 | 11:42 AM
bronze's Avatar
bronze
Is it possible to see it fluctuating dramatically and if so what would cause that? What kind of fluctuation would be considered "dramatic"?
Old May 18, 2023 | 11:45 AM
It should be pretty stable. If you get more than say, 5 psi fluctuation, time for a new pump.
Old May 18, 2023 | 11:48 AM
bronze's Avatar
bronze
Thanks.
Old May 18, 2023 | 01:07 PM
onemore94dak's Avatar
onemore94dak
There is a 1995 factory service manual in the FAQ section that you can download.
The pressure is listed as 35-45 psi. I didn't see anything about fluctuation. That said fluctuation is usually a sign that a pump is giving out. Any kind of pump.
