long starts.
Old Jan 24, 2006 | 08:01 PM
94Dakota318's Avatar
94Dakota318
Default long starts.
i got a 94 dodge dakota.. just put a fuel pump in it, and after i put it in, its taking like 5 seconds to crank and then start.. i tried the trick where you turn the key to on, and let it pressurize and still the same thing???
Anyone have any info ,or remidies?
Old Jan 25, 2006 | 01:50 AM
360DakotaPwr's Avatar
360DakotaPwr
Default RE: long starts.
Check the fuel pressure and see if its correct when its running. This should halp to see if its any good or not. I think it should be about 40 psi for 94
Old Jan 26, 2006 | 06:08 PM
94Dakota318
The FP is 41 when ideling... i dont know what the hell is going on.. and it sucks it cranks it seems for ever.. maybe i just got a bad pump???
Old Jan 26, 2006 | 08:55 PM
360DakotaPwr
Doubtful, if the pressure is 41. Have you checked you plugs and see if you have a good spark. Are you running good gas? Is your timing correct. Maybe even clean the idol speed motor port, also have a friend look at it while you try to start it with the air cleaner off. See if you can see any movement at all.
Old Jan 27, 2006 | 12:12 AM
stantheman's Avatar
stantheman
got the same problem, but after working on cars all day i really just dont want to mess with it. i know i need to and i hope its not my pump. hope ya find out what it is and if i do ill get back with ya. maybe a little motivation to find what it is on my part.
Old Jan 27, 2006 | 06:34 PM
94Dakota318
i put brand new plugs in
how and where is the idol speed motor port???? and how do i clean it?
and what should timing be?
Old Jan 27, 2006 | 09:21 PM
360DakotaPwr
Idol speed port is the sensor on the rear of the throttle body. Take it off and clean it with some carb cleaner.
Take it to the dealer, they may not even charge you, they can set the distributor correctly. With a timing light you can see what it is at idol and compare it to a value you would have to look up. Its not going to ba advanced much at idol.
Old Feb 5, 2006 | 01:51 PM
Gone Fishin's Avatar
Gone Fishin
The timing on your DAK is ECM controlled, unless you pulled the dist. out its hard to get it out of time. Try depessing the throttle slightly when starting to see if that helps. There is a diagnostic for IAC in the manual (Haynes).and is simply done. There are a few other possibilities. Check your fuel pressure when you are just ready to start the truck. It is possible that the injector screens have become clogged with rust flakes--this usually shows up when your driving--severe unexlainable power loss. Clogged fuel filter. When you changed the fuel pump out, did you use new connector hose and good clamps? It is also possible that the fuel return regulator (on the fuel rail) is going bad, or you may have a vacuum leak on the actuator hose.
