Steering problems
Old Feb 9, 2006 | 08:41 PM
91V8dakota's Avatar
91V8dakota
Default Steering problems
I need some HELP. i have a 91 5.2L 4X4 and while driving, i am constantly fighting the steering wheel to the point where my hand hurts later on.Now ive put new tires on it,new shocks,had a shop that i trust replace a cracked idler arm and a broken pitman arm and an alignment done.AND the truck still fights with me .Its not like a truck out of alignment because it runs straight if you dont touch it on the interstate. I just dont understand and neither could a buddy who works at repair shop.thanks for your help
Old Feb 10, 2006 | 08:57 PM
360DakotaPwr's Avatar
360DakotaPwr
Default RE: Steering problems
If its hard to steer, then maybe the power steering pump isnt putting out. I think you have power steering right?
Old Feb 12, 2006 | 02:23 AM
91V8dakota's Avatar
91V8dakota
yeah my truck has power steering .the pump looks fine a local MOPAR guy i talked to said it might be that the steering gear is wore out.i sure hope thats not the problem cause those things arent cheap.anyway thanks for the help..
Old Feb 12, 2006 | 04:01 AM
cool dakota's Avatar
cool dakota
Big tires will also feel any and every rut in the road. This will cause the truck to drive itself, like following a track. Also make sure all tires are inflated to the proper PSI.
Good luck
Old Feb 12, 2006 | 04:02 AM
cool dakota
Good luck
Old Feb 13, 2006 | 01:12 AM
360DakotaPwr
Yes, a bad steering gear will make the steering sluggish
Old Feb 15, 2006 | 03:41 AM
JDakota92's Avatar
JDakota92
I'm taking a steering class right now. I'll see if I can help. Does it pull to any particular direction? When? Have you had the ball joints checked? Bushings? How about the shackles and leaf springs in the rear? Ask the shop you had do the alignment check the thrustline with the geometrick center line. If their a good shop, they'll know those terms. The two lines should line up on top of each other. There is a lot of angles the shop can check. Whether or not they actually checked them, is another thing. Is your steering wheel centered?
Old Feb 16, 2006 | 07:52 AM
91V8dakota's Avatar
91V8dakota
Ive had the truck aligned and the shop said the ball joints are okay.the stering wheel is also straight too.besides the steering gear the only other thing thats not right is i got some new tires to go on the front 235 75 r15 but i havent put any on the back yet.and the tires on the back are really bald and treads almost gone. you dont think that could have anything to do with itdo you. thanks guys
Old Feb 17, 2006 | 03:33 AM
JDakota92's Avatar
JDakota92
It can yes. It can also throw off the alignment and balancing of the wheels. Get new tires on and see what happens then.
