'93 Dakota, want to install 2" body lift, soon!
Old Sep 30, 2006 | 02:55 AM
moparfire's Avatar
moparfire
Default '93 Dakota, want to install 2" body lift, soon!
Hey guys and/or girls, I have had my 1993 since last March. I bought a Performance Accessories body lift and want to install it sooner than later. The directions are as vague as they come. If anyone has installed this lift, do you have any pointers? Any trouble that i may run into? So far I understand that I will have to move or trim the fan shroud, weld the shift linkage extension and take the clips off some wires to allow them to move. I could really use the help, since I rather not install it in my unheated garage in a Minnesota winter. Also, did anyone replace the body bushings at the same time if the were worn? Thanks for any help in advance.
[IMG]local://upfiles/45340/F8FDE6C86C384B2C874149131D5F4410.jpg[/IMG]
Old Oct 1, 2006 | 03:40 PM
moparfire's Avatar
moparfire
Default RE: '93 Dakota, want to install 2" body lift, soon!
So nobody has ever installed this kit before? That seems to be the case if no one even attempts to reply. The purpose of a forum is to share information and ideas, so i am a little disappointed. At least at jeepforum.com, they reply to your question whether it is common sense to some or just stupid to others. I feel i have a pretty good concern, being I have never installed a body lift before? Some help please, I'm asking nicely!
Old Oct 1, 2006 | 11:12 PM
dodgerules86's Avatar
dodgerules86
Never installed a lift kit. Sorry.
There are a few people wandering around here with modified Gen 1. Dakotas, but, since the newest of these Gen 1 trucks are 11 years old... this section doesn't get a whole lot of traffic.
Old Oct 2, 2006 | 04:30 PM
fishlessman's Avatar
fishlessman
i bought my 89 new, and the only thing ive been dissatisfied is how little aftermarket stuff is out there for it.i dont think many have done a lift, so finding your answers may be hard. i lifted mine with the torsion bars up front to level it off the first year i had it, maybe a little over 1.5 inches. the back could be easily lifted with a block under the leafs. some trucks came stock with a body lift, i think mine was 1.5 inches, but dont remember.
Old Oct 2, 2006 | 07:15 PM
moparfire's Avatar
moparfire
I read somewhere that a guy put Dodge Ram 2500 springs on the rear, anyone heard of that? Thanks for replying guys, I was losing hope. Have you noticed any wear on the front end with the torsion bars cranked? Did you have an alignment done afterward? How about extended brake lines, does the front get stretched when you raise it? Thanks again
Old Oct 2, 2006 | 07:53 PM
dodgerules86
Ya know, I believe the torsion bars on mine are cranked. It seems to sit pretty level. If they were cranked, it was done before I bought it. I can't speak for increased wear on the front end (IIRC, they said increased wear is possible, but, I don't specifically remember). I do need some new front-end parts, but, with 98,000 miles, its not suprizing.
I can't speak for the 3/4 ton springs, but I know lots of people have done lots of upgrades to their Dakota, so it wouldn't suprize me. (I'm stock so I can't say anything for experiance ).
Old Oct 3, 2006 | 11:54 AM
fishlessman
mine is low milage, but the tires wore fine. i did have it aligned after lifting with the torsion bars. i wouldnt go over about 1.5 inches . my first car was a dart and i raised it pretty high, the lower ball joints would wear, but it could have been my driving style at the time.
Old Feb 26, 2008 | 03:54 PM
pembroke dude's Avatar
pembroke dude
Hi there hows it going?
I have put the 2 inch lift in my 94 dakota and it took two of us about three hrs to install it. just a little tip for ya , remove the bolts on one side of the truck and loosen the other side alot this will keep everything aligned when u install the lift one side at a time.
I cut the fan shroud to make it fit. The only problem i ran into was a break line from the master cyl to the frame was to short and had to be replaced with a longer one. I also replaced one bad mount while i had it apart. Good luck with the lift .
PS mine did not come with bumper brackets i had to make my own.
Old Feb 26, 2008 | 11:29 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Ya the kits are eazy I installed mine a while back. Its worth it. They dont sell the bumber brakets. But easy to modify your stocks ones. you should post some pics pembroke dude
