looking to swap engine
Old 03-19-2017, 09:40 AM
muncey's Avatar
muncey
muncey is offline
Default looking to swap engine
I have a 1991 dodge dakota 3.9, and looking to swap the engine to a 1995 dakota 3.9 magnum. Do I have to use the wiring/computer for 1995, or could i use the 1991 wiring/computer?
Old 03-19-2017, 10:40 AM
onemore94dak's Avatar
onemore94dak
onemore94dak is offline
Short answer, No. There were a lot of changes from 91 to 95.
Old 03-19-2017, 11:02 AM
muncey's Avatar
muncey
muncey is offline
thanks for your help. so I do need the 91 wiring/computer. the 95 wiring/computer will not work. ? thanks again
Old 03-19-2017, 11:29 AM
Carl_S's Avatar
Carl_S
Carl_S is offline
I think you'll need wiring and comp. The 95 Mag will be multiport injection and the 91 is throttle body.
Old 03-19-2017, 11:33 AM
muncey's Avatar
muncey
muncey is offline
that's what I was thinking to. for your help
Old 03-19-2017, 11:56 AM
RalphP's Avatar
RalphP
RalphP is offline
You'll also have to swap out the speedometer (the 1991 is mechanical; the 1995 is electronic), and quite possibly most of the interior wiring.
When you add the reduced power output of the 1991 V6, I have to ask "WHY???"
I'd get the 1995 rebuilt first, if at all possible.
RwP
Old 03-19-2017, 03:06 PM
muncey's Avatar
muncey
muncey is offline
the 91 has been in a wreck with a bent frame the motor is good with 61000 on it. the 95 has 185000 and the motor has a heard knocking on the bottom end of it . i was planning to swap motor and the automate transmission
Old 03-19-2017, 05:55 PM
RalphP's Avatar
RalphP
RalphP is offline
Pick up the FSM for both the 1991 and the 1995; compare the two.
Sadly, there's not that much common in the wiring.
(Could be worse, could be a 1996; THAT was an almost complete rewiring job due to the switch to OBDII and the RE series of transmissions.)
RwP
Old 03-19-2017, 06:45 PM
muncey's Avatar
muncey
muncey is offline
thanks I will
