wrong ECU injectors = low MPG?
Old 08-10-2017, 11:08 PM
onemore94dak's Avatar
onemore94dak
onemore94dak is offline
Default wrong ECU injectors = low MPG?
I was wondering if a previous owner had changed out the ECU. I have a rebuilt set of injectors sized for the 94 3.9 about 2 or so years old. The O2 Sensor is 3 years old. I'm getting around 14-15 mpg's. When I did the plenum before I changed the injectors I got 19 mpg's on that first tank of gas which was mostly hwy miles. Then it started going downhill and has stabilized at 14-15.
Old 08-10-2017, 11:59 PM
Toby Warford's Avatar
Toby Warford
Toby Warford is offline
Being I know your good at preventative maintenance, I wont state the obvious.
but, often times people neglect the cat. You have inspections iirc. How old is the converter?
I do however forget what your truck is: v8 or v6 2 or 4 wheel?
Old 08-11-2017, 10:36 AM
onemore94dak
CAT is about 2 years old its a 3.9 2wd
Old 08-11-2017, 06:45 PM
onemore94dak
OK Tires were low, down to <30PSI which is odd since they have less than 7500 miles on them new. Edit-I used my tool to tighten the stems. I detected no looseness.
What brand O2 Sensor is meant for the 94 3.9?
Old 08-12-2017, 12:49 AM
Toby Warford
Bosch.
Old 08-12-2017, 10:16 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,178 Likes on 2,931 Posts
Originally Posted by Toby Warford
Bosch.
Really? Were those stock equipment? I know some of the newer trucks really dislike the bosch sensors.....
Old 08-15-2017, 05:55 PM
volaredon's Avatar
volaredon
volaredon is offline
nope. Dodges don't seem to like the Bosch sensors at least not for very long. Look for NTK, that was OE.
Old 08-15-2017, 09:54 PM
Toby Warford
mine has been doing great for 40k+ miles.
Old 08-15-2017, 10:01 PM
HeyYou is offline
Lucky.
Old 08-19-2017, 07:07 PM
volaredon's Avatar
volaredon
Lucky.
X2.... I usually get a year if I am lucky out of a Bosch branded O2.
