freeze plug
Old May 19, 2007 | 02:59 PM
kjun's Avatar
kjun
Default freeze plug
I'm changing out my water pump and noticed a freeze plug (front right) is leaking. I did a search on replacing it and from what I see I basically take a socket and tap it into the block. Then I pull it out with a needle nose. Pardon my ignorance but I'm not sure I understand. If it is big enough to seal the block. How would it be small enough to come out?
Also if I can get it out when I replace it I just tap in the new one until flush. Do I put any type of sealant on it. Thanks in advance
Old May 19, 2007 | 04:04 PM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: freeze plug
Some people use RTV . But anything is okay as long it is sticky, and will seal. Be sure when you put the new freeze plug in it matches up with the others. Don't drive it in to far.
Old May 20, 2007 | 02:10 AM
kjun's Avatar
kjun
Thanks for the advice. Got her done. Overall pretty easy. Just a little on the messy side with all the coolant. So far so good.
