1999 Durango Overheating
Old Jul 27, 2007 | 12:12 PM
jtm45ak's Avatar
jtm45ak
Default 1999 Durango Overheating
I have a '99 Durango, 45K miles, Engine was overheating, thorough coolant flush w/ new coolant, still overheating, replaced thermostat, still overheating especially with the A/C on. Any ideas with next step on what to do ? Thanks
Old Jul 27, 2007 | 12:49 PM
cesspool's Avatar
cesspool
Default RE: 1999 Durango Overheating
Whenyou ay overheating do you mean it's getting warmer than you like or it's peging out the needle? Are you losing fluid? Is the fan working properly?
Old Jul 27, 2007 | 01:08 PM
jtm45ak's Avatar
jtm45ak
It's overheating to the point of almost red-line. All pressures tested out OK at Firestone Shop. And yes it does spill out some coolant from the overflow tank after I park it. Fan does work OK. Thanks !!
Old Jul 27, 2007 | 02:19 PM
cesspool's Avatar
cesspool
I'd try another stat just to be sure, or test yours in a pan of water.
Old Aug 1, 2007 | 09:55 PM
master tech's Avatar
master tech
Site Moderator & Tech
Ck and see if you have an electric fan and if it is coming on by actuating it.
Old Aug 1, 2007 | 11:15 PM
kjun's Avatar
kjun
Try the rad cap!!!!
Old Aug 2, 2007 | 12:00 AM
Durango911's Avatar
Durango911
Install a 180 T-stat,make sure your clutch fan is operating properly(replace if it's worn out),test your coolant,water pump might be going bad(it doesn't have to leak in order to be worn out!)
Old Aug 2, 2007 | 11:14 AM
jtm45ak's Avatar
jtm45ak
Thanks guys, I'll keep trying with these ideas....
