Overheating Help!!
Old Aug 24, 2007 | 01:47 PM
RTSport's Avatar
RTSport
Default Overheating Help!!
[:@]I have a 2001 4.9 Durango that has overheated with no coolent leaking. Temp gage went all the way to Hot and I pulled over and had it towed home. What DIY test can I do to find this reason for this[:@] overheating issue. Fan, Thermastat, Raditator ???[:@]
Old Aug 24, 2007 | 01:50 PM
Mean Green's Avatar
Mean Green
Default RE: Overheating Help!!
I would replace the t-stat first.
Old Aug 24, 2007 | 01:52 PM
RTSport's Avatar
RTSport
Ok I have been looking under the hood and damned if I can see the Therm=Goose neck ?
Old Aug 24, 2007 | 01:53 PM
Mean Green's Avatar
Mean Green
Let me look in my manual real quick I don't have the 4.7 but you should just follow the upper radiator hose and you will find it.
Old Aug 24, 2007 | 01:56 PM
RTSport's Avatar
RTSport
Yes It should be but damn I can't see it.
Old Aug 24, 2007 | 01:57 PM
Mean Green's Avatar
Mean Green
Ha!, It is on the bottom of the engine I'm uploading a pic to photobucket give me a sec.
Old Aug 24, 2007 | 01:58 PM
Mean Green's Avatar
Mean Green
Here you go
Old Aug 24, 2007 | 02:00 PM
RTSport's Avatar
RTSport
Thanks man I would never of found that !!
I owe you one !!
Old Aug 24, 2007 | 02:06 PM
Mean Green's Avatar
Mean Green
Make checks payable to Mean Green @ DF. [8D]
Old Aug 24, 2007 | 04:05 PM
bigbaddurango's Avatar
bigbaddurango
Dont for get to check out the water pump and make sure your fans are working as well
