Front End Noise while turning
Old Oct 26, 2007 | 06:55 PM
adam35's Avatar
adam35
Default Front End Noise while turning
I have a 2002 Dodge Durango that emits an odd rubbing noise (similar to the noise made when trying to make tight turns in 4WD) whenever making moderate to severe turns. The noise only occurs when moving and does not occur when just turning the steering wheel. Does anyone know what could be causing this noise?
Old Oct 26, 2007 | 11:07 PM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: Front End Noise while turning
Try adding grease or wd40 to the lower ball joints.
