Which tires???
Old 02-16-2008, 11:34 PM
daddy_bear_21's Avatar
daddy_bear_21
daddy_bear_21 is offline
Default Which tires???
Ok, we are in need of some new tires, as the front ones are shot to heck. The rears are ok, but we are looking to have a matching set on the truck for once, the previous owners put mismatched tires on. We are debating between an A/T and a Mud tire, I am looking to keep stock size, 31-1050-r15. I am not wanting to go too expensive, but want a decent tire. I was looking at the BFGoodrich A/T KO and the BFG mud tire, anyone have any experience with these, or would you recommend one over the other?
Thank you,
Bear
*EDIT* This is for a 99 D 5.2 part time 4x4, all stock at the moment.
Old 02-17-2008, 12:51 AM
OneBadKota's Avatar
OneBadKota
OneBadKota is offline
Default RE: Which tires???
You can't beat the BFG All-Terrain. Really good tire.. Kind of up on the list for price, but worth it.
Old 02-17-2008, 01:29 AM
daddy_bear_21
Are the AT's better than the MT's? Given the price difference, is there really that noticable of a difference in performance?
Old 02-17-2008, 02:26 AM
OneBadKota's Avatar
OneBadKota
If it's the M/Ts I am thinking of, they're not that great. The A/T gives a nice ride on the road and good traction off the road.
Old 02-17-2008, 02:30 AM
daddy_bear_21
BFG MT
BFG AT
Those are the 2 I am looling at, but am open to other tire suggestions...
thank you for the replies
Old 02-17-2008, 02:37 AM
OneBadKota's Avatar
OneBadKota
Yep, those M/Ts I personally dislike. Also, you don't often get many miles off them as you would the A/T.
I like Michelin M/S tires as well, but those're usually more expensive and will corrode aluminum rims if not kept with Nitrogen.
The Michelins will get often more than not way over the miles on the tire it is rated for. From personal experience they usually double their rated mileage.
It really depends what you do more.
If more on-road than off, T/As
If more off-road than on, Toyos
If just on-road and no off-road, the T/As or M/Ss(You will get more bang for your buck from the Michelin's if properly kept up... rotates, proper air(nitrogen)..
Old 02-17-2008, 02:51 AM
daddy_bear_21
you recommend the toyo's for more off than on, why is that? I like the look of the toyo's, but dont want to spend the money on a tire that would not hold up to daily driving. We will be running this truck off road, as much as we can, but it is also a daily driver. I like the look of the BFG AT's too, so we may be going with those. Thank you again for the help
Old 02-17-2008, 12:17 PM
OneBadKota's Avatar
OneBadKota
I had the Toyos on the GFs truck, it was kind of a rougher ride but they really grab snow and mud. The A/Ts are quieter.
Most tire places will let you try a tire for 30 days or 1,000 miles(I believe are the right numbers)
So, start with what you most want and go from there.
Good luck and no problem.
Old 02-17-2008, 01:03 PM
Kensai's Avatar
Kensai
Kensai is offline
I would go for the A/T's. I personally own 3 sets of them in my lifetime and the treadwear is amazing even with abuse, I still got almost 60k miles per set. The M/T's are strictly for mudding so if you are gonna mud around most of the time, go with the M/T's, otherwise, the A/T's are good for most road surfaces.
The M/T's are also rough riding and noisy. Maybe you can own both sets and just swap out your A/T's to M/T's when needed.
Old 02-17-2008, 03:59 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
BFG KO's 31X10.5X15 is what I run. I love em!
Quick Reply: Which tires???
