help suspension!!
Old Apr 15, 2008 | 03:45 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
Default RE: help suspension!!
umm not sure what you mean hydra, but the only people that have ever worked on the truck are me and my dad(with the exception of the ball joint recall work) so i dont think a mechanic screwed it up on me
Old Apr 15, 2008 | 06:26 PM
deerang's Avatar
deerang
no problem shtr..
I'm gonna replace my shocks and prolly those jouncers too once I start working again this spring, pretty sure my shocks are original with 270,000 km on them.. I know I have one blown (or on its last leg), i get wierd bounces on the highway... I've yet to decide if its right rear or front left..
Old Apr 15, 2008 | 09:43 PM
shrpshtr325
THE ULTI-MOD
the fronts tend to go first especially if you have the tow package w/ the heavier duty rear shocks
at least on mine i think the fronts are shot (at 72000 i think they lasted plenty long enough for the origional shocks) if you want to chekc them take the shochk off and pull and push on it if you can compress nad extend it by hand then they are shot
Old Apr 16, 2008 | 12:09 AM
deerang's Avatar
deerang
I don't want to take out the shocks unless I'm gonna replace them... and I'm gonna replace all 4 when I do..
i replaced just the rears on my moms VW last summer, and now the thing feels like a boat on the highway.. hit a big bump and the back sticks, but the front bounces two or three times..
Old Apr 16, 2008 | 02:59 PM
shrpshtr325
THE ULTI-MOD
yea well i cant afford to do all four so im just going to check and replace the fronts if they are bad, but honestly the backs hold up pretty good as long as you dont tow often
Old Apr 16, 2008 | 05:12 PM
hydrashocker's Avatar
hydrashocker
HMMMM.....
Maybe the D's come from the factory with the bump stops that close.
Does anyone with the tortion lift give up a measurement?
Old Apr 17, 2008 | 03:07 PM
shrpshtr325
THE ULTI-MOD
that is what i am hoping and that if i replace them and the shocks that i will then be ok for anothe 70k or so but well see ill update you guys this weekend
Old Apr 20, 2009 | 11:03 PM
hydrashocker
If the front end height measument isn't set then it sits too close and hits the bump stops ripping them appart. This happends if it is set to low and not at 73mm. Here is the service manual. You measure to the knucle in the middle of the Tortion Bar to the gound then to the center of the hub.
STANDARD PROCEDURE
STANDARD PROCEDURE - HEIGHT
MEASUREMENT - 4WD
The vehicle suspension height MUST be measured
and adjusted before performing wheel alignment procedure.
Also when front suspension components have
been replaced. This measure must be performed with
the vehicle supporting it’s own weight and taken on
both sides of the vehicle.
(1) Inspect tires.
(2) Jounce the front of the vehicle.
(3) Measure and record the distance between the
ground and the center of the lower suspension arm
rear mounting bolt head (Fig. 2).
(4) Measure and record the distance between the
ground and the center of the front wheel (Fig. 2).
(5) Subtract the first measurement from the second
measurement. The difference between the two
measurement should be 73 mm (2.9 inches) ± 3 mm
(0.12 inches).
ADJUSTMENT - 4WD
To adjust the vehicle height turn the torsion bar
adjustment bolt CLOCKWISE to raise the vehicle
and COUNTER CLOCKWISE to lower the vehicle.
CAUTION: ALWAYS raise the vehicle to the correct
suspension height, NEVER lower the vehicle to
obtain the correct suspension height. If the vehicle
suspension height is too high, lower the vehicle
below the height specification. Then raise the vehicle
to the correct suspension height specification.
This will insure the vehicle maintains the proper
suspension height.
NOTE: If a height adjustment has been made, perform
height measurement again on both sides of
the vehicle.
Fig. 2 Height Measurement
DN
WHEEL ALIGNMENT 2 - 3
WHEEL ALIGNMENT (Continued)
STANDARD PROCEDURE - CAMBER AND
CASTER ADJUSTMENT
NOTE:
4X4 SUSPENSION HEIGHT MESUREMENT
MUST BE PERFORMED BEFORE AN ALIGNMENT.
Old Apr 21, 2009 | 12:05 AM
shrpshtr325
THE ULTI-MOD
holy odl thread man!!!!!!!!!!!!!!!! , but thanks for the info good to know
Old Apr 21, 2009 | 10:58 PM
hydrashocker
Just thought I'd add this to the senerio.
