Dodge Duranogo Problems
Old Sep 4, 2008 | 03:39 PM
spyder98's Avatar
spyder98
Default Dodge Duranogo Problems
Hi guys....
I have a 99 Dodge Durango with the 5.9L I have a Vortech SuperCharger. Well ive been getting a 2 check engine lights with one being 1494 and the other is 0442. what do i need to replace to get rid of the check engine light. My second problem which is 100 times worse than the check engine light is my D sometimes turns off with no warning. it turns off at various speeds after waiting 15-30 minutes the D turns right back up and work fine. Can this be the PCM? any help will be appreciated
Old Sep 4, 2008 | 09:39 PM
IndyDurango's Avatar
IndyDurango
Yes, the outage is more than likely the PCM.
Your Supercharged 1999 a Blue Shelby Durango?
IndyDurango
Old Sep 5, 2008 | 09:16 AM
hydrashocker's Avatar
hydrashocker
It's all emissions:
P1494 Leak Detection Pump Switch or Mechanical Fault
P0442 Evaporative Emission Control System Leak Detected (small leak)
Not to good in the emissions department but it sounds like a vacume leak. Check the gas cap.
It is normal that sometimes a small leak will trigger the system then turn off.
Old Sep 5, 2008 | 10:27 AM
spyder98's Avatar
spyder98
No its not the shelby i wish lol.....well i checked everything out and i cleared the codes yesterday i drove 50 miles and the truck ran fine... today i drove for 16 miles and the truck ran fine but as soon as i put it in park i got the check engine light i checked it and it says 0420 now what can that be can all these codes be caused by a bad pcm?
Old Sep 5, 2008 | 10:35 AM
DRO318's Avatar
DRO318
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
Old Sep 5, 2008 | 10:52 AM
spyder98's Avatar
spyder98
in that case what do i need to replace?
Old Sep 5, 2008 | 11:30 AM
hydrashocker
It's a P0442 Evaporative Emission Control System Leak Detected (small leak) not a P0420.
I would replace the gas cap.
Use the search at the top of the page and search advanced for the P0442 and you will find plenty of info on it. Just search in the Durango 1st generation area. Here's one from the search.
https://dodgeforum.com/forum/showthr...ighlight=P0442
Old Sep 5, 2008 | 11:44 AM
spyder98's Avatar
spyder98
no i actually did get P0420 thats the only one im getting now. 3 days ago i did get the one you metioned the P0442 and 1494 but i reset them and they havent come back up.
Old Sep 7, 2008 | 12:46 PM
spyder98's Avatar
spyder98
how can i check to make sure the timing is correct? Does anyone have a spark plug wire diagram so i can make sure the wires are set correctly?
Okay well i cleared the codes again. I want to see which ones I get a second time so i can replace them and i got the 1494 so i will be replacing the LDP on tuesday. Know the wierdest thing happend twice the D stalled which thats normal by now but when i went to restart it it started back up but with a really low RPM and i could here a type of knocking sound then the D turned off by itself and what seems to be the exhaust smoke came out of the intake filter? would a clogged cat do this?
Old Sep 8, 2008 | 08:10 AM
hydrashocker
I am wondering about a crank shaft sensor located under your distributor. They look like a set of points. Speaking of which, have you replaced your cap, rotor, and wires?
And also what about a vacume leak?????
