Engine Smoothness
Old Sep 17, 2008 | 04:53 PM
wordsworth's Avatar
wordsworth
Default Engine Smoothness
My car is Dodge Durango year 2000. And I have problem in the engine smoothness, it is not stable sound, it goes up and down while in still position or driving. Nothing was done except spark plug and its wires were replaced but the problem is not resolved yet. The fuel injection system never maintained since five years.
Old Sep 19, 2008 | 09:50 AM
hydrashocker's Avatar
hydrashocker
1. It could be the IAC sensor located on the TB.
2. Did you replace the Cap and Rotor?
3. Clean the TB and while you have it off look inside to see if you have any oil build up.
Old Sep 19, 2008 | 12:15 PM
Haplucki's Avatar
Haplucki
Thumbs down Re
Do you want my opinion GET rid of it cause after you fix that problem there will be another
Old Sep 19, 2008 | 12:48 PM
hydrashocker
Now just because your havin some problems that could be fixed, don't be BITTER!
Old Sep 19, 2008 | 04:52 PM
n8ech's Avatar
n8ech
For idle issues, replace the TPS. I will bet money that this cures your problem.
TPS333 at Autozone, or you favorite place. $40.
Don
Old Sep 19, 2008 | 08:26 PM
DRO318's Avatar
DRO318
Exclamation Take a chill pill
Dude you must understand... Vehicles in general have parts that break. Every car has maintenance issues some diff than others. As mileage on the odometer goes up parts will need to be changed. If one can not handle it, maybe they should get a bike and start pedaling.
Dodge makes great sturdy engines that last a long time.
Old Sep 22, 2008 | 09:17 AM
hydrashocker
^LOL ^
If you take care of your truck it will take care of you period.
Old Oct 8, 2008 | 07:22 AM
wordsworth's Avatar
wordsworth
Guys, thanks for the replies, I have been away for sometime, hydrashocker, i have not changed the cap or the rotor , and i will check IAC sensor and oil build on..and will get back to you.
Don, thanks for the reply, hope it is what you bet for , let me check and i will get back to you?
Regards,
Old Oct 8, 2008 | 12:20 PM
DRO318's Avatar
DRO318
Cool Hey
Regards,
Hey glad to see ya back. I was going to suggest that you take off the TB and clean it along with the IAC.
Old Oct 9, 2008 | 05:24 AM
Mean Green's Avatar
Mean Green
I would second the TPS. What plugs did you use when you changed them also? Our D's are very picky when it comes to the plugs you put in them. I have had good luck with plain old OEM Champions and I am on a set of autolite 3923's.
As for the troll get a life and mainain your ride. Until you have that figured out stick with a Kia or Hyundai then at least when you kill one of those you won't be out all that much money...
