check engine light??? P0455
Old Jan 20, 2010 | 10:15 AM
  #61
Dans01Durango's Avatar
Dans01Durango
Any auto parts store will have hoses of diff. sizes for sale. IMHO, you should get the hoses rated for gasoline so teh fumes won't rot them out.
Old Mar 19, 2010 | 09:36 PM
  #62
bskicrash1's Avatar
bskicrash1
that code could be caused by something as little as a pin hole in your filler tube. Since its a first generation, its fill tube is probably rusted enough to not let it hold pressure. The evap system holds a 1 PSI pressure.
Old Mar 19, 2010 | 11:12 PM
  #63
MAGIC84's Avatar
MAGIC84
If you are referring to the hoses by the vapor canister on the drivers side frame inboard approx between the drivers and left rear passengers seat, this is the hose repair.
I got about 6 inches of 3/8 hose and 6" of 7/16th hose (rated for fuel as Dan said) and a universal coupler. Also some small no more than about 3/4 inch hose clamps. X4
Attach the rotted hose to the canister, clamp, then to the coupler and clamp. Repeat step for the other side of the affected hose. I installed mine in 07 and have been good to go so far, but now that the weather is warming up and it has been three years this might serve as a good reminder to check again when I get back from my trip this weekend. When I replaced mine Auto Zone had excess hose, so didnt charge me for them, only thing I got charged for was the couplers and clamps, about $6.00 total.
Took about 10 minutes to remove and replace.
FYI Autozone at least will not clear codes anymore, they may allow you to "borrow" the scanner and turn a blind eye, but their corporate is cracking down on clearing the codes, they will read, print and recommend repairs but not clear. You either have to get another scanner or use the battery reset procedure.
Old Mar 20, 2010 | 12:31 AM
  #64
hydrashocker's Avatar
hydrashocker
When i had an issue with the ABS sensor on the rear (which lead into a total rear end rebuild) I went to Checker Auto and they just gave me a scanner and asked me if I knew how to figure it out which I replied "Yes" and they let me pull the codes. They just trusted me with their scan tool but that was it (I couldn't erase the codes) however i could find out the issue.
