newbie needs some upgrade advice
Old Nov 17, 2008 | 11:56 PM
  #31
hydrashocker's Avatar
hydrashocker
Originally Posted by Facory
Unfortunately, the front end steering looseness is typical of the 1st generation Durango. I own the 5.9 SLT 4WD HD transfer case. Have chased this problem since I bought it. I have replaced ball joints, power steering pump, sway bar bushings (only because they squeaked), steering gear twice, shocks. The greatest improvement came from replacement of the steering gear. It took two from NAPA before we got one that was tight. I normally don't even notice the looseness anymore. It's not as tight as a sports car, but it's acceptable. I have 16" Michelin 275's which could add a little more travel to get them turning. If you have a 1G Durango you will just have to live with it.
3 words, Steering box adjustment.
Second an HD transfer case????? Do you mean the NV 242 HD???? The transfer case whould not have anything to do with it.
The other thing is if the Torsion bars are not in parallel then this could happen as well as other multiple component wear like shocks and tie rod ends.
Old Nov 20, 2008 | 09:13 PM
  #32
ChrisHackIT's Avatar
ChrisHackIT
Question turbo/supercharger
guys,
can you get a twin turbo kit or a supercharger for the D 4.7L ????
let me know
hydra: thanks for the advice
Old Nov 22, 2008 | 06:02 PM
  #33
deerang's Avatar
deerang
this is the best I've found.. its for a ram
http://www.kennebell.net/supercharge.../47ramsohc.htm
Old Nov 23, 2008 | 06:36 PM
  #34
ChrisHackIT
Deerang,
I was going to ask if you were free this weekend, if so can you zip down to whitby I need a 2nd opinion I would appreciate the advice and also you seem to know more than myself, let me know?.
Cheers,
ChrisHackIT
Old Nov 23, 2008 | 06:45 PM
  #35
ChrisHackIT
Question wooing noise, driving, ,left front end
Guys,
I have a wo-wo-wo when I am drive at regular speed(60KMS) and on the highway. Last year I had my hubs replaced on both sides, the company who makes them is called SKF, I am now wonder if that is the hub or something else, any help from you guys would be much appreciated. I guess soon the damn right front is gonna do the same s*** again?, s*** happens.
Hope you all had a great weekend.
Cheers,
ChrisHackIT
Old Nov 23, 2008 | 06:58 PM
  #36
DRO318's Avatar
DRO318
check into your brakes
Old Nov 24, 2008 | 06:15 PM
  #37
deerang's Avatar
deerang
I could meet you sat or sunday morning. send me a pm and we'll work out some details.
Old Nov 25, 2008 | 03:27 PM
  #38
ChrisHackIT
deerang,
check your private messages let me know if that's OK time
Cheers,
ChrisHackIT
Old Nov 26, 2008 | 04:13 AM
  #39
Mean Green's Avatar
Mean Green
Can I come too???
Old Nov 26, 2008 | 05:12 AM
  #40
deerang's Avatar
deerang
yea man! NV to Whitby wouldn't take you that long.. I'm sure you could knock it off in less than 24 hours if you really tried.. In fact, I bet you $100 you can make it here in 24 hours or less!!
