What is this connector?
Old Jan 4, 2009 | 09:48 PM
schusterjo's Avatar
schusterjo
Default What is this connector?
I am thinking perhaps this is a diag connector but not sure. (always thought green is diag). It sits above the transmission and is just above the extension housing (overdrive).. If it is not a diag connector where the heck does it go? I just swapped out my tranny and this particular plug i did not find where it goes. (I am not getting full lockup, it slips in and out. The extension housing is off my old tranny and OD worked fine on it))
http://i289.photobucket.com/albums/l...s/SSPX0199.jpg
http://i289.photobucket.com/albums/l...s/SSPX0198.jpg
Old Jan 4, 2009 | 10:10 PM
Neo1130's Avatar
Neo1130
That is your O2 sensor connector... Then again, I cannot tell as the pics aren't the best quality...
Old Jan 4, 2009 | 10:56 PM
schusterjo's Avatar
schusterjo
O2 are plugged in.. this wire comes strait out of the wire harness running above the tranny
Old Jan 4, 2009 | 11:11 PM
master tech's Avatar
master tech
Site Moderator & Tech
Is your truck a 4x4? If so, that maybe the connector to the transfer box.
Old Jan 4, 2009 | 11:57 PM
schusterjo's Avatar
schusterjo
Yes it is a 4X4.. if it is that connector where in the heck is the plug in? I can't find it anywhere..
Old Jan 5, 2009 | 10:31 PM
master tech
On top of the t-case.
Old Jan 8, 2009 | 05:06 PM
schusterjo's Avatar
schusterjo
Thanks, master tech.... You the man, it was in fact the transfer case connection. I did not remove the transfer case during the removal and install of the new transmission, just slid it back out of the way.. So it must of came undone when I slid it back and I did not see it. had somebody else helping me so I might of not even been under it at that moment. anyways thx a bunch for helping me find out where it went.
