cold weather trans wows
Old Jan 8, 2009 | 05:46 PM
maddog138's Avatar
maddog138
Question cold weather trans wows
its 15 degrees and my durango only shifts to 3rd. till it gets warmed up. any suggestions?
Old Jan 8, 2009 | 06:27 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
its normal, the tranny will not shift into OD (4th gear foryou) until it is up to operating temp
(i am assuming that you have a 4 spd overdrive auto tranny)
Old Jan 9, 2009 | 11:10 AM
Mean Green's Avatar
Mean Green
Mine shifts fine when cold but it is ideal to stay out of OD until the tranny is warm. Was this something that was changed with the 01's and up or is a feature of the 4.7? My wifes car actually won't shift into 3rd until it is a little warm and won't shift to OD until it reaches operating temp.
Old Jan 9, 2009 | 08:57 PM
hydrashocker's Avatar
hydrashocker
I have this build into mine. (1998 46-RE)
It's on the other trans (except 4.7L) because if the trany slips into overdrive being that cold it can take OD out. This was a saftey that was installed into the PCM as a fail safe and let me say that it is a good one at that.
The radiator also cools the trany fluid but also warms the fluid (this warms the trans) which alows better flow of fluid into direct areas (because of the transmission bands in ours). It will shift well before it's warm up but, is intended to engage at temps around 32 degrees F or below.
Old Jan 10, 2009 | 12:12 AM
shrpshtr325
THE ULTI-MOD
im pretty sure it IS on the 4.7s (and all the others) bc mine wont hit OD until is warm, but i got a 5 spd auto in mine so its not as big of a deal to be stuck w/ only 4, i usually keep OD off around town anyway, and im warm before i hit the highway
Old Jan 10, 2009 | 09:29 AM
Mean Green's Avatar
Mean Green
Mine does not lock me out of OD.
Old Jan 10, 2009 | 10:47 AM
shrpshtr325
THE ULTI-MOD
how cold does it get where you live? it has to be below freezing to lock you out (i think thats what someone above said) but mine locks me out till everything is up to NORMAL operating temps
Old Jan 12, 2009 | 12:59 PM
hydrashocker
Thats strange Sharp. I think you need to replace your temp sensor.
BTW......that someone was me.......LOL
Old Jan 12, 2009 | 11:04 PM
Mean Green's Avatar
Mean Green
Well Sharp it may surprise you but we have a ski resort right up the road here in Reno. It's been near 0 degrees some mornings when I leave for work.
Old Jan 12, 2009 | 11:58 PM
shrpshtr325
THE ULTI-MOD
really, mean, i AM surprised, and hydra, the truck has supposedly(according to my parents) done it since it was brand new, (they drove it out of the showroom back in 02) so im pretty sure that its supposed to do it,
