P0753 Code Issues
Old Jan 22, 2009 | 09:07 AM
westwind77's Avatar
westwind77
Just a follow up as I hate when people post problems but never the solution...
The PCM was bad. They dropped the pan, replaced the filter and all solenoids/sensors and it made no difference. A friend of a friend of a friend of the shop had a D that matched mine, (exact yr options, etc). They swaped PCM's and mine ran perfect and his tossed the code.
I sent mine out to be reman'ed, should have it back in about a week.
Thanks for all the help...and....it hurts to say it... the dealership was right, for once!
Old Jan 22, 2009 | 05:33 PM
schusterjo's Avatar
schusterjo
Hummm... I am wondering if this is my problem now. my 3-4 shift is still not fixed and have almost eliminated everything but the PCM/TCM
Old Jan 24, 2009 | 06:41 PM
Mean Green's Avatar
Mean Green
Weird...
Old Apr 15, 2009 | 10:37 PM
moparornocar91's Avatar
moparornocar91
Could someone send me the pdf file if there is any, on where these relays and solenoids are? I keep having p0753 and p1765 come off and on, and will loose my lower gears it seems. Is there any easy fix such as a fuse or relay under the hood? or am I going to have to take apart my tranny?
Old Apr 16, 2009 | 09:01 AM
westwind77's Avatar
westwind77
FYI - The solution to my problem (reason the thread was started) was to replace the the PCM. I had the shop swap with a like D and it worked fine. I found a place on line that sells reman'ed PCM's, purchased, installed, and about 2k miles on it and no problems since.
Old Jul 11, 2009 | 09:53 PM
foxfirey2k's Avatar
foxfirey2k
Default thanks
thanks, for the post I have the same problem on my 2000 D. I did the same thing you did. Change the tcc and o/d, Governor solenoids sensors, and oil fitter. With on help. My transmission Guy wonts to cut the wiring harness. I said no thanks and drove off. I will try the pcm.
Old Jul 12, 2009 | 03:12 PM
hydrashocker's Avatar
hydrashocker
Well we tried.......
Thanks for the update and I hope we didn't discourage you? Sometimes everyone is wrong but we always try to minimize the repair bills.
moparornocar91<----- As for location on the trans:
Solenoid Replacement and Location:
https://dodgeforum.com/forum/1st-gen-...ml#post1695983
foxfirey2k<----- Good job running!
Old Jul 14, 2009 | 11:16 PM
foxfirey2k's Avatar
foxfirey2k
Unhappy update
I took my durago the shop today and had the pcm tested. they said it failed I need a new one. Does any have good place to order one?
Old Jul 15, 2009 | 01:16 PM
hydrashocker
I've seen pre-flashed versions on www.ebay.com
After replacement they need to be flashed by the dealer unless you get a preflashed one.
Old Jul 15, 2009 | 03:10 PM
schusterjo's Avatar
schusterjo
I am getting a broken link
