99 durango cuts off
Old Feb 4, 2009 | 04:52 PM
mhalstead3's Avatar
mhalstead3
Default 99 durango cuts off
My 99 dodge durango cuts off when I put it into reverse. Got any ideas?
Old Feb 4, 2009 | 05:48 PM
dukhunter's Avatar
dukhunter
do you have a remote start?
Old Feb 4, 2009 | 07:08 PM
hydrashocker's Avatar
hydrashocker
Could be the trany locking up.
Try to have the trans serviced which means a fluid and filter and a band adjustment.
Make sure the shop only uses ATF+lll, or ATF+4 which is Fully Synthitic.
Old Feb 4, 2009 | 11:08 PM
master tech's Avatar
master tech
Site Moderator & Tech
mhalstead3
Is the engine stalling when you put the trans in reverse? If it is, like hydrashocker had said trans locking maybe torque converter, could also have other problem too. reverse band to tight, ck ball on separator plate ( valve body) or even the PCM. try removing the eatx relay and put the trans in reverse, if it doesn't stall then the problem is in the PCM or wire.
