E fan
Old Mar 3, 2009 | 02:03 PM
Jasperstang308's Avatar
Jasperstang308
Default E fan
so i reading on DOC about the flex a lite fan. would this fan be satisfactory enough for DD and the very occasional towing? Also my 01 durango already has an electric fan on it does the flex a lite fan replace it AND the clutch fan?
also how does it make the ac cooler? i saw that comment was made as well. This was one of my primary reasons for maybe going this route. i already have the thermal tape on order to wrap the ac lines
Old Mar 3, 2009 | 03:50 PM
hydrashocker's Avatar
hydrashocker
A felx fan pulls enough air for what you want. The difference is, the cluch fan takes some HP to run where the flex doesn't take as much. The clutch fan WILL pull in more air when engaged because it stays rigid. The flex fan flatens out at high RPM but at low RPM pulls more air. It becomes a trade off...... More HP and gas mileage or work vehical?????
The electric fan is a back up for the cluch fan. You want to leave it unless you go to a fully electric fan which if you want more info look here. In here you can find a lot of questions you need answered:
Do It Yourself (top questions and answers)
This is on the main thread board.
Old Mar 4, 2009 | 01:17 AM
Jasperstang308
is this not a full electric fan?
http://store.summitracing.com/partde...5&autoview=sku
i thought this is what you all recommended since it comes with the controller for it as well
Old Mar 4, 2009 | 07:25 AM
Duranged408's Avatar
Duranged408
Im pretty sure your first post was mis-understood, as i was confused too. We thought you meant their flex fans (which are a direct replacement for the factory fan and bolt to the existing clutch). We recomend teh black magic kit because it does pull enough air to cool our engines and would work. I have the 180 black magic with controller and it does the trick, keeps me cool even when im pulling tractor sleds haha. It free's up extra hp due to the clutch/stock fan weight being removed in the belt system (less drag). The efan having better flow/better control is the contributor to a cooler AC radiator. When the supplied controller is tied into the AC circuit it kicks on and stays on whenever AC is used, now if it blows cooler air in your face i dont know, but the increased airflow on the ac's radiator should improve something.
Old Mar 4, 2009 | 07:28 AM
Duranged408
Old Mar 4, 2009 | 07:31 AM
Duranged408
I purchased my kit from Moesperformance.com over at dakota-durango.com. They are a vendor and their prices (in cart) will/would be cheaper for the BM180 fan.
http://moesperformance.com/index.php...products_id=15
Old Mar 4, 2009 | 01:23 PM
Jasperstang308
thats quite a price drop. do you know where i can get a cold air intake for a good price
Old Mar 4, 2009 | 10:45 PM
hydrashocker
Look here again! Do It Yourself (top questions and answers)
And in there you will find this:
Custom made Front RAM air intake
https://dodgeforum.com/forum/1st-gen-...ir-intake.html
https://dodgeforum.com/forum/1st-gen-...e-ram-air.html
This is one of the best CIA's you can get. Remember to search and look in there to find what you need before posting.
