cv shaft play????
The proper name is a CV Half Shaft, however it is the full unit meaning the inner end plugs into the front axle shaft and on the outer side it plugs into the hub. It is the entire shaft. This is a somewhat large job so if you feel more comfortable to take it in then do so, if you want to tackle it there is instructions here: https://dodgeforum.com/forum/1st-gen...wers-faqs.html
When the boot tears debris stick inside of the grease and thus make their way into the bearings. When this happens it's like putting sand into a bearing and it tears them appart. Replacing a CV boot is a good way around buying one IF you catch it as a small hole. Also you have to have proper tools to do this. In your case you stated that it was cracked so I assume that it's contaminated.
As for preventative maintanence:
You CV boot lasted 8 years! Thats a good run anyway you look at it. Things like salt, heat, and many other things can shorten the life of the CV boot depending on your driving enviorment and style, but in reallity there is nothing you can do but replace it when it is needed.
