Rough idle... Found this forum too late..
Old 04-08-2009, 07:34 AM
Jmodix's Avatar
Jmodix
Jmodix is offline
Maybe.. But wouldn't injectors also give me problems while my foot is on the gas driving?
Something else I noticed... If the AC or Heat is on, the truck runs fine.. no more studdering.
  #32
Old 04-08-2009, 03:57 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
Vacuume leak!
  #33
Old 04-08-2009, 05:21 PM
Jmodix's Avatar
Jmodix
Jmodix is offline
Is there an easy way to check for Vac leaks?
Also is there a diagram somewhere of all the vac lines? I'll check my haynes manual.. havent seen anything in there for that but I wasnt specifically looking for it either.
/crossmyfingers
  #34
Old 04-08-2009, 10:12 PM
IndyDurango's Avatar
IndyDurango
IndyDurango is offline
/crossmyfingers
Use a propane torch. Unlit I've heard.
IndyD
  #35
Old 04-08-2009, 10:32 PM
hydrashocker
Under the hood on the hood should be a diagram. Also Chiltons manual.
VEHICLE EMISSION CONTROL
INFORMATION (VECI) LABEL
DESCRIPTION
All vehicles are equipped with a combined VECI
label. This label is located in the engine compartment
on the inside of the hood passenger side.
The VECI label contains the following:
²
Engine family and displacement
²
Evaporative family
²
Emission control system schematic
²
Certification application
²
Engine timing specifications (if adjustable)
²
Idle speeds (if adjustable)
²
Spark plug and gap
The label also contains an engine vacuum schematic.
Quick Reply: Rough idle... Found this forum too late..
