need advice!!99 durango
Old Mar 23, 2009 | 05:43 PM
dscdad77's Avatar
dscdad77
Default need advice!!99 durango
I cut out my cat and went straight pipe to a magnaflow. Will I have to do anything differant in setting up sensors and such. will the o2 sensors read correctly? My truck has been great and i don't want to **** it off any more.
Old Mar 23, 2009 | 05:51 PM
schusterjo's Avatar
schusterjo
Well I know this is what I would use....
http://www.thefastman.com/02Simms.asp
If you just remove the cat, and possibly the post cat O2 sensor you will get irratic idle, loss of performance, and a never ending MIL light ...
Old Mar 23, 2009 | 06:08 PM
dscdad77's Avatar
dscdad77
what should i do? replace both sensors? I heard something about putting a resistor on the sensor? all i know is the truck is running like crap right now.. thanks for your input, i appreciate it
Old Mar 23, 2009 | 06:22 PM
schusterjo's Avatar
schusterjo
Replacing them is not going to do a thing.
I am sure there probably is another way but that is the only one I know of.
Old Mar 23, 2009 | 08:47 PM
DRO318's Avatar
DRO318
I heard some one a while back say putting a spark plug anti fouler on them does the trick don't know how true it is, but it's cheap
Old Mar 23, 2009 | 09:06 PM
DragonOfMadness's Avatar
DragonOfMadness
This link has some things for tricking the ecu and also enabling you to set some parameters on your own...I've never fooled with the dodge o2 trickers but the I messed with some 5.0 ford stuff that worked pretty well as long as you don't over do it..I did run across sometrhing else about the last o2 not being used except to make sure the cat was there=I'll try to dig up the link I found on that..I like the link Shuster left=that looks like a very interesting device...
http://www.streetbeatcustoms.com/199...ormance-Chips/
Old Mar 24, 2009 | 08:29 AM
Duranged408's Avatar
Duranged408
First and foremost, only thing removing the cat does is make it louder, actually i retract that, it also decreases performance a smudge. The guys at Dakota-durango.com can help you out with the whole O2 issue, i forgot what they did either leave the front O2 in and the secondary against the frame or somethin, idk. O2 simms are only made to replace one sensor so the other still stays in the upstream.
Old Mar 24, 2009 | 11:28 PM
IndyDurango's Avatar
IndyDurango
+1. No good reason to eliminate a CAT on the Durango. Stock Cats are high-flow and stainless as is. If it need replaced, go back on with a stocker and get another 200,000+ miles out of it.
IndyDurango
Old Mar 24, 2009 | 11:30 PM
IndyDurango
dup post
