Strange whistle sound at very light throttle...
As of the past two months, I have been getting a strange whistle sound while driving on the freeway ONLY at VERY light throttle... When I say light throttle, I mean, all I have to do is put my foot on the pedal, no pressure, and the noise appears... It does this for the first 1/8" - 1/4" of throttle input... I don't know if anyone here has heard a 2nd Gen Neon with an intake, but the throttle body whistles pretty loud... It sounds pretty close to that but is fairly quiet compared to the Neon... It has been getting louder the past couple of days though so starting to have me worried...
Also, a while back when I was installing my stereo, I accidentally hit something right above the gas pedal and it started to hiss... Sounds like a vacuum reservoir maybe but I checked all lines and they are good... I don't get any CEL or anything and the vehicle runs okay... Thinking maybe that leak is getting bigger causing the whistle? What is above the gas pedal there that could leak like that?
1999 Durango 5.2L....
The whistle I've had for 4 years and it is just there....... IDK....... When I installed my new motor, K&N and even my Fastman 52mm TB it still did it. Even through each upgrade. I noticed even more profound sound now so I know it's just the air going into the TB.
If it's a vacuum leak-then take an UNLIT propane torch and run it near where you hear the whistle=the propane will caus the idle to go up when it gets sucked into the motor and it's not a fire hazard as long as there's nothing sparking..you could also try blocking off all the vacuum ports and just route the Map sensor hose to a vacuum port and seeing if the whistle goes away then if it does just reconnect each hose seperatly till you finf it-it maybe in the vacuum line that operates the heating cooling switching system vent operation...
Kinda strange hu?
Dude puttin a torch un-lit isn't a smart thing to do?????? I do see your point.
What I was getting at is on my truck it's in the incoming air. Second you can oly hear it at a certin RPM with the throttle plate in the right place.
an UNLIT propane torch can find alot of vacuum leaks especially intake leaks, hoses-etc and it is safer then using starting fluid or carb spray...but I forget I'm surrounded by top techs who spit in old school ways....What ya can't discern incoming air from a vacuum leak=Let me take another shot of whiskey on that.Cheers=lol
Trending Topics
Yes it is... Reminds me of that one commercial, I think it was Meineke who had that commercial. You know the one where it had several people making funny noises describing their car issues.
I'm game for trying the propane. I love old school methods. Often more reliable and easy to accomplish. Sounds as good as anything I guess. Anyone have a cigarette?
IndyD
