Another issue
Old Apr 3, 2009 | 03:44 PM
teck78's Avatar
teck78
Unhappy Oil pressure issue
Ok fixed the ABS/brake light thanks to you guys. Now i was looking at changing the plugs and stuff. i just got the rig a few ago and noticed that the engine temp never really got hot. so i change the thermostat. th eold one was in pieces. Now i have a lifter tick and a check gauges light. Oil pressure reads 0...what the hell. the more i fix the more they come....what would be a good fix for this new issue. would the cold engine temp for who knows how long cause this. the temp before the fix was about 130 degrees. or should i just change the oil with a thicker one? I am getting tired of fixing stuff
you guys saved me before, i hope you can do it again
Old Apr 3, 2009 | 04:18 PM
hydrashocker's Avatar
hydrashocker
Could just be the octane.
First please help me out with your year and motor?
Old Apr 3, 2009 | 10:48 PM
teck78's Avatar
teck78
Thumbs down Oil pump?
Does anyone know how about how long it takes to change out a oil pump on a 99 5.9 4x4 durango? Looks like mine took a dump lifter noise and no oil pressure? i am thinking of farming it out to the shop. Way to much crap in the way for me to do it in the drive way. Damn durango.....fix one thing and well you know...
T
Old Apr 3, 2009 | 11:28 PM
schusterjo's Avatar
schusterjo
Well you pretty much have to remove the engine.. if you have no oil pressure it is time for a rebuild or buy used. Simply replacing the oil pump may end up being a waste of money if there is other damage.
Old Apr 3, 2009 | 11:34 PM
DragonOfMadness's Avatar
DragonOfMadness
dude,ya need to check ur oil pressure with a mechanical gauge....If ya got atleast 15 psi at idle and 50psi at 2000rpm ya good...as for 130degree do ya think we are stupid?
these motors are not runin at 130 =210 would be a high point...please post engine and year specs...And don't Damn a D-rang=these are the most rugged suv you can buy as long as you address their quarky mantainence needs....
Old Apr 4, 2009 | 12:54 AM
teck78's Avatar
teck78
Default oil pressure...
1999 Durango SLT
5.9 liter 4x4
136K
ok well then the thermostat was broke and i took a laser temp of the head and it was no joke 132 degrees. the radiator was 126 degrees. i removed it it was in 4 pieces and now reads about 195. the oil pressure gauge is reading 0, the check gauges light is on my lifters are ticking like crazy and that pretty much leads me to think that the oil pump is out or the pick up is broke/blocked.
T
Old Apr 4, 2009 | 11:54 AM
teck78's Avatar
teck78
Exclamation Remove the engine?
First i would like to say thanks for all the help you guys have been giving me. You have made the gremlins on the Durango slowly go away.
Now is there any other way to drop the oil pan on a 99 5.9 4x4 Durango without removing the engine? How many hours will a shop charge me to do this?
T
Old Apr 4, 2009 | 02:46 PM
IndyDurango's Avatar
IndyDurango
Just drop the pan and sometimes you need to loosen up the crossmember.
IndyD
Old Apr 4, 2009 | 04:36 PM
hydrashocker
Front diff needs to come out or lift the motor.
Also the problem could be a cavitated filter so give it an oil change and replace the filter first.
Old Apr 6, 2009 | 08:36 AM
DRO318's Avatar
DRO318
^ +2 on that^
