Question?
Old Apr 14, 2009 | 10:12 AM
FAMILYMAN12's Avatar
FAMILYMAN12
Question Question?
ok yesterday coming home from work as i was getting off of the freeway i here a clunk after that as i am driving it is making a real funny banging sound so i look at the driverside everything is fine go to the passenger side and there is only one lug nut and stud left everything else has broken off. so my question is what could have caused this? i have never taken this tire off in the seven months i have owned the durango
Old Apr 14, 2009 | 11:25 PM
IndyDurango's Avatar
IndyDurango
loose lugs?
The D had a recall on the BJs. Basically, the stock BJs suck and the recalled BJs suck too. Both will get old and fail. Since you have just added a ton of stress to the wheel area with all the lugs off and the results that have came from that... have the TREs and the BJs evaluated for repair/replacement. You do NOT want to be driving along and loose the front tire off the D entirely. It has happened and with the knowledge thats out there, it is fully preventable.
IndyDurango
Old Apr 14, 2009 | 11:52 PM
hydrashocker's Avatar
hydrashocker
The last person to chage your tires or balace them didn't tighten them properly. Once a shop removes your tires and replaces them after 25 miles you are suppost to check them...... It's written in the contract you sign (work order).
They can come loose even if they were torqued because torquing is streching the bolt and once you do this (from the factory) a bolt cannot be properly torqued again, thus relating to the disclaimer.
Old Apr 15, 2009 | 12:02 PM
Neo1130's Avatar
Neo1130
Originally Posted by IndyDurango
BJs suck
lol
Old Apr 15, 2009 | 02:13 PM
IndyDurango
Lol..!
Old Apr 15, 2009 | 06:01 PM
hydrashocker
^ Smart asses! ^
Old May 7, 2009 | 11:17 PM
FAMILYMAN12
Unhappy
yeah had to change the whole hub there was only one lug nut and stud holding the tire on thank god it did not come off well again guys thanks
Old May 7, 2009 | 11:55 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
Originally Posted by Neo1130
lol
damn it you beat me to it
