Just hit 100,000 miles. CEL
I don't think the light will clear by itself, you can clear it with the obd scanner or battery clear, remove the negative cable for about a minute or two and reconnect. Remember how to reset the clock.
Charcoal canister is on underside, about at the drivers front door, inner frame, looks almost box like. Check all hoses remember flashlight, let us know what you find. Look for obvious leaks but also not so obvious such as cuts, pinhole leaks, loose clamps, check the canister itself.
As for fuel door, no clue better check with the veterans you maybe able to get lucky enough to find a D and a Ram owner.
Good luck!!!!
Good luck!!!!
