Durango AC issues
Old May 20, 2009 | 11:28 PM
silvertoy's Avatar
silvertoy
Default Durango AC issues
Hi iam new here and having ac issues on my 2003 durango.it was working when i went into the store,but when i came back out and started it up the ac is blowing hot.when we tried to put 134 in it would not take it,and the line Froze up.
Old May 21, 2009 | 12:16 AM
IndyDurango's Avatar
IndyDurango
Is it okay now?
Don't run the AC on max without the fan on in either of the top two speed positions.
If it unfroze (which it will when you turn off the D) then you need to add freon. While you can add a can to see if that helps, if it needs more than that, go have it refilled professionally.
HTH,
IndyDurango
Old May 21, 2009 | 08:42 AM
silvertoy's Avatar
silvertoy
Was looking into it today,and all the rear's are blowing cold air but the front vent's are not.what now anyhelp thanks jason.
Old May 21, 2009 | 06:02 PM
schusterjo's Avatar
schusterjo
if your rear is working and your front is not then you have a dash issue, its not allowing the airflow valve to switch correctly..
Old May 21, 2009 | 10:43 PM
hydrashocker's Avatar
hydrashocker
Blend door?
Old May 21, 2009 | 11:16 PM
IndyDurango
Naaa.
Low freon.
Just needs pulled down and recharged based on the info we have so far.
IndyD
Old May 22, 2009 | 09:21 AM
silvertoy's Avatar
silvertoy
Think we have found what is going on,waiting for the part to get here and will post up what it was.
Old May 22, 2009 | 03:35 PM
hydrashocker
Expansion Valve?
Old May 26, 2009 | 10:23 AM
silvertoy's Avatar
silvertoy
Yes the Expansion Valve was bad,see all good now.
Old May 26, 2009 | 02:38 PM
IndyDurango
Wouldn't the valve had shown up during a routine recharge?
Glad you got it fixed!
IndyD
