1999 Dodge Durangon SLT 5.9 Engine Removal
Old Jun 2, 2009 | 06:01 PM
hydrashocker's Avatar
hydrashocker
P&P the heads. Other than that sounds good. I doubt your heads are good though!
Old Jun 2, 2009 | 09:19 PM
schusterjo's Avatar
schusterjo
LOL engine is easy to pull compared to "just" dropping a transmission out of a Durango 4X4.... I would be happy to pull an engine over the tranny drop anyday..
Old Jun 3, 2009 | 07:14 PM
2000D's Avatar
2000D
I am glad I have a 4x2
Old Jun 3, 2009 | 10:54 PM
hydrashocker
Engines are easy in retrospect.
Old Jun 6, 2009 | 11:03 PM
S S0DEN's Avatar
S S0DEN
Job completed, install was a lot better...
5.9 is sitting on the stand waiting for me to order a rotating assembly and the machine shop...
5.2 installed in the mean time, FYI no ECM flashing or reprograming required. Truck runs very good with no trouble codes. Plugs look great after 100 miles of drive time.
Old Jun 7, 2009 | 12:36 PM
schusterjo's Avatar
schusterjo
Ya, i have not personaly done the 5.9 to the 5.2 swap but have read much about it and knew the PCM was not an issue for others.. If it was then a flash could be done at the dealer for $60 but nobody I read that had done it had to. Far as the connections and such they are the exact same for the 5.9 and the 5.2... No special wiring needed.
Glad its working out for you. keep us updated.
