Need Help on removing door panels
Old Aug 13, 2009 | 01:11 AM
shippy21's Avatar
shippy21
Default Need Help on removing door panels
A friend of mine has a 1998 Durango and she bought new speakers for the rear doors. Problem being, I do not know how to remove the door panels without breaking the door handle piece on the inside. Thus being said I also need to know how to replace the inside door handle as to someone else broke it before me so now the door will not open from the inside. Please help anything will be greatly appreciated. Thank You
Old Aug 13, 2009 | 02:22 AM
IndyDurango's Avatar
IndyDurango
There are a series of levers made of thin steel rods on the inside of the handles. Probably one of those came off or the clip that holds it in place popped off/broke. Easy fix.
There is a screw behind the handle. Pull it out and you will see it. There are only 4 screws holding in the rear door. Once they are out, lift up and off. Check out my link to "Locks Squealing - Part Deux" for rear door removal photos in this DF thread:
https://dodgeforum.com/forum/1st-gen...g-heavily.html
HTH,
IndyDurango
Old Aug 13, 2009 | 04:22 AM
shippy21's Avatar
shippy21
Thanks alot man. Greatly appreciated.
Old Aug 13, 2009 | 04:00 PM
schusterjo's Avatar
schusterjo
Welcome to the forum
Old Aug 14, 2009 | 01:08 PM
Kensai's Avatar
Kensai
Do a search in the 1st gen durango forum for speaker install. I have placed a link on the DIY on door removal. It is really easy to do. short summary, The doors have a total of about 6-7 screws, when you lift up on the door panel, you will get access to unclip the plastic retainer holding on to the rods and able to disconnect the electrical harness to the door lock/windows.
It will take you about 30-45 minutes if you are a first timer, but once you got the hang of it, door removal takes about 5 minutes. I replaced all my OEM infinity speakers with aftermarket Infinitys.
Old Aug 14, 2009 | 09:21 PM
hydrashocker's Avatar
hydrashocker
Make sure you replace them with 2 ohm speakers. Regular 4 ohm will NOT work.
Look in here: Do It Yourself (top questions and answers) FAQ's
Old Aug 16, 2009 | 07:48 PM
SumAmerican's Avatar
SumAmerican
make sure to reuse the thick speaker to door mounts.. I had some problems with the windows after I tried to forgo reinstall those.
Old Aug 17, 2009 | 01:17 PM
Kensai's Avatar
Kensai
Look in the DIY section stickied in this forum. There is a link to a thread that I have made on replacing the speakers as well as repairing the OEM speakers.
