2003 4l7L Front seal leaking
Old Sep 6, 2009 | 05:05 PM
theandies's Avatar
theandies
Default 2003 4l7L Front seal leaking
NooB here, never really had any problems with my Durango but recently the front seal bearing at the harmonic balancer started leaking. Does the timing cover have to come off to replace it or can the HB (and anything in the way) just be pulled for replacement? Any info is apprciated.
Thanks
edit- I don't know why my title messed up. It's a 4.7L
Old Sep 7, 2009 | 11:34 AM
theandies's Avatar
theandies
Bump to the top.
Old Sep 21, 2009 | 10:28 AM
theandies's Avatar
theandies
No one knows????
Old Sep 21, 2009 | 12:52 PM
hydrashocker's Avatar
hydrashocker
You can go to here and download the manual:
http://pdftown.com/Dodge-Durango-Service-Manual.html
CRANKSHAFT OIL SEAL—FRONT
REMOVAL
(1) Disconnect negative cable from battery.
(2) Remove accessory drive belt refer to Group 7,
Cooling System for procedure.
(3) Remove A/C compressor mouning fasteners and
set aside.
(4) Drain cooling system. Refer to Group 7, Cooling
(5) Remove upper radiator hose.
(6) Using Special Tools 6958 Spanner with Adapter
Pins 8346 loosen fan and viscous assembly from
water pump (Fig. 126).
(7) Remove fan and viscous assembly.
(8) Disconnect electrical connector for fan mounted
inside radiator shroud.
(9) Remove radiator shroud attaching fasteners.
NOTE: Transmission cooler line snaps into shroud
lower right hand corner.
(10) Remove radiator shroud.
(11) Remove crankshaft damper bolt.
(12) Remove damper using Special Tools 8513
Insert and 1026 Three Jaw Puller (Fig. 127).
(13) Using Special Tool 8511, remove crankshaft
front seal (Fig. 128).
INSTALLATION
CAUTION: To prevent severe damage to the Crankshaft,
Damper or Special Tool 8512, thoroughly
clean the damper bore and the crankshaft nose
before installing Damper.
(1) Using Special Tool 8348 and 8512, install
crankshaft front seal (Fig. 129).
(2) Assemble Special Tool 8512 as follows, The nut
is threaded onto the shaft first. Then the roller bearing
is placed onto the threaded rod (The hardened
bearing surface of the bearing
MUST face the nut).
Then the hardened washer slides onto the threaded
rod (Fig. 130). Once assembled coat the threaded
rod’s threads with Mopar
t Nickel Anti-Seize or (Loctite
No. 771).
(3) Align crankshaft damper slot with key in
crankshaft. Slide damper onto crankshaft slightly.
(4) Using Special Tool 8512 press damper onto
crankshaft (Fig. 131).
(5) Install then tighten crankshaft damper bolt to
175 N·m (130 ft. lbs.).
(6) Install radiator shroud and tighten fasteners to
11 N·m (95 in. lbs.).
(7) Connect electrical connector for shroud fan.
(8) Install fan and viscous assembly.
(9) Using Special Tools 6958 Spanner with Adapter
Pins 8346 tighten fan and viscous assembly to water
pump (Fig. 126).
(10) Install upper radiator hose.
(11) Install A/C compressor and tighten fasteners
to 54 N·m (40 ft. lbs.).
(12) Install accessory drive belt refer to Group 7,
(13) Refill cooling system. Refer to Group 7, Cooling
(14) Connect negative cable to battery.
Old Sep 22, 2009 | 11:14 AM
theandies's Avatar
theandies
Awesome - Thanks!
Old Sep 22, 2009 | 10:18 PM
hydrashocker
Have a great time on the forum!
PS......Your welcome!
Old May 15, 2011 | 01:18 PM
jds_jeep's Avatar
jds_jeep
Anybody know the password for that manual I just downloaded from Rapid Share with the link above?
Old May 15, 2011 | 03:23 PM
hydrashocker
The password is: PDFtown.com
Yes it looks like a .com address but that is actually the password.
You can also go here and download multiple manuals and other info with no password.
http://www.mediafire.com/?sharekey=c...b5ba589d1986ba
Parts Manuals: http://www.mediafire.com/?jh24tgfi6i694
