Need to know OEM torque converter number
That looks like a TPS. Replace it and modify to .72 volts to ground......(middle wire).
I thought you said a different year. I would replace the TC solenoid and install a Shift Kit. Call Transgo and ask them BC I seen the actually have a few for your 44RE. Might look into the pump as well.
Replaced all sensors and governors in the tranny (all 3)
Those have been ruled out.
What I am left with is,
Torque converter
Valvebody blocked
Bad O/D (extension housing) unit
did not get the piston bearings/spacers correct during the install (but we checked and checked before we dropped it on so this would be one of the last things i would check)
I think it's: Shaft Size=1.5" Housing Bore=2.249" Outer Diameter=2.253" Width=0.36"
You first want to go oversized torque convertor and would suggest Hughes Performance http://hughesperformance.com/catalog_online/
26 spline on the 44RE I think. The 46RE has the 23 spline.
3000 rpm stall Hughes:
A500 OD Lockup w/26 spline 1993- '04 .............................. 16-30L
