Torsion Key and Shackles to lift a D
Old Sep 12, 2009 | 04:06 PM
Disturbed Durango's Avatar
Disturbed Durango
Default Torsion Key and Shackles to lift a D
Hi Guys me again
So I already have a 3" Body lift now id like to get another 2"
My qustions are
The Torsion Key's
Like these http://phoenix.backpage.com/AutoPart...Ad?oid=1953185
Do they add a couple inches?
And if so how difficult are they to install?
And I know that the shackle lifts will get about 2"
Id love to get a Rancho Lift kit but they are way outa my current price range.
The other idea I had was skip the Shackle lift and put in an ADD-A-Leaf
Any thoughts or ideas and info is greatly appreciated
Thanks guys
Chad
Disturbed Durango
San Antonio TX.
Old Sep 14, 2009 | 07:25 AM
Duranged408's Avatar
Duranged408
Re-indexed torsion keys are just like throttlebody spacers, useless. Just crank up your current torsion bolts 8 full revolutions. As for the shackle/add a leaf etc that decision is up to you. I chose belltech 6400 shackle.
Old Sep 14, 2009 | 08:29 AM
rzramon's Avatar
rzramon
Hi Durango,
I am pretty much agree with the comment given by Duranged. But instead of 8 full revolutions, 3 to 4 revolutions will do a lot but remember after doing this drive your vehicle few feet front and back so that it will help the the suspension to fix in better position.
Regards,
Razor
Old Sep 14, 2009 | 06:59 PM
rebelboy's Avatar
rebelboy
i cranked mine 5 times and put bigger shackles gain alittle under 2 inches from frame to ground
Old Sep 14, 2009 | 10:51 PM
hydrashocker's Avatar
hydrashocker
Now it's 4 turns per inch for a total of 8 full turns. Now remember that you need to start from OEM height at 78mm lower from wheel center to torsion centering marking point on the front end. Then install the Belltech 6400 shackle. Then a 4 wheel alignment to reset the front end camber.
Old Mar 17, 2011 | 11:01 PM
DangRango_orby's Avatar
DangRango_orby
I know this will sound stupid, but where exactly do I need to look to do the torsion lift?
Old Mar 17, 2011 | 11:45 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
you just turn the torsion bar adjusting bolts 8 turns for 2 inches of lift in the front, and get 2 inch lift shackles for the rear
Old Mar 18, 2011 | 01:20 AM
DangRango_orby
right, but where under the durango is it exactly? do i need to take off my skid plates to get to them i guess is a better question
Old Mar 18, 2011 | 12:39 PM
Evon Trizmo's Avatar
Evon Trizmo
Follow your torsion bars back to the transmission crossmember and there's 2 big bolts sticking out around there, one for each side, you can't miss them. Those are the ones you have to turn but do as hydra said and start off at 78mm just to be sure you don't over crank the bars and damage anything.
Basically you're all set on raising your front end, don't have to buy/add anything there just crank up the torsion bars 8 turns on each side. On the rear just install the shackles on your leaf springs and you're all set.
Old Mar 18, 2011 | 01:56 PM
Mastec's Avatar
Mastec
As a reference they are located directly under the driver and passenger seats. You can't miss them.
