towing big enclosed trailers. need advice
#61
#62
Found the spindles at a dismantler/recycler about an hour and a half from me - $70ea (side) for the complete spindle/caliper/hub/rotor assembly. Not like I need the extra pieces, but that's what it comes with. I'm actually going to go pick those up in the morning (he was "sending a guy to go pull the parts off the vehicle" this afternoon after I got off the phone with him. Literally... fresh picked from the field like your favorite veggies.
Kind of a waste I guess since I'm getting the rotor and calipers, but I'm going to replace the calipers with rebuilts anyway just to be sure that they are up to snuff. I haven't figured out what I want yet for pads... but I know I want cross-drilled/slotted rotors, and I'm leaning towards Baer. Anyone have an opinion? Also, since the calipers are "still installed", I'm thinking that I probably don't need the caliper bolts that Dan's write-up referenced having to order from the dealership. Oh, and I'm hoping that the backplate/splash-shield is included as well since it's the whole spindle/hub assembly I'm getting.
<fingers crossed>
#63
#64
#65
Then go buy you some Hawk LTS or if you are towing more severe loads, get the Hawk SuperDuty pads.
#67
got tranny cooler in tonight. had a little trouble with the brass fittings. some did not want to seal properly. used some teflon tape on the threads, i dont know if that was the right move or not. i may have to buy some o-rings to put inside of them if that does not work.
the tranny cooler did not have the proper fittings, so we had to match them up with adapters to get it to the correct size to screw in to the radiator.
i will check in the morning if there are any leaks. i hope not, as i dont want to get back in there again tomorrow.
#69
looks like i have small drip from the fitting into the radiator when it runs. i dont know if i can put a o-ring just inside the opening or not. i dont cant see if it just opens up to the tank or if there is a lip where a o-ring would sit and seal the threads.
the bad part is, that is the one fitting that you have to take off everything to get to.
#70
